Sunroof hose installation: Best practices.
Roadrunner505
Karma: +7 / -6   Thank you, like it!
Post29-09-2004, 8:49    Subject: Sunroof hose installation: Best practices. Quote
I had an original electric sunroof installed in my Passat 35i.
Now I need to install the drainage hoses in columns A and D.
Does anyone have any experience with how to best get them all the way into the wheel wells?
Translated on 12-09-2026, 8:05.
Marco
Post01-10-2004, 11:06    Subject: Sunroof hose installation: Best practices. Quote
Unfortunately, I don't have any experience with that, but I'm saying this before anyone else chimes in.
I would probably try using welding wire or something similar. If you glue the drainage hoses to the wire, they should be able to be pulled through the columns.
Translated on 12-09-2026, 8:06.
wolfi_b
Post01-10-2004, 22:08    Subject: Sunroof hose installation: Best practices. Quote
Or with an electrician's cable puller. Those are designed for that purpose.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
No new posts Golf 1J documentation up to 05/99, sunroof stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Sunroof Rattle Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Sunroof Repair (8L, up to 08/2000) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts B4 Avant, 1Z - Best way to connect to the OBD port Transmission, Chassis, Body & Interior
No new posts Best way to glue rubber: Tips & tricks. Transmission, Chassis, Body & Interior
No new posts Drive Shaft Damage: Best Verification Methods Transmission, Chassis, Body & Interior
No new posts {QUESTION} - Where is the best place to tap into the {TERM}? On-Board Diagnostics (OBD)
