WarLord Guest
18-10-2004, 18:31 Subject: Diesel filter and the funny spider: What kind of wrench? |
Since I have removed the diesel filter's drain, and as a result, the part is no longer completely sealed (especially at the bottom, and the VW engineers also haven't made it completely sealed), I'm interested in knowing what size wrench/socket is needed to get a replacement. Separating the filter from the spider should be quite simple, right? (just unscrew it or something)
Okay, the vehicle is a Passat 3B with a 115 PS PD engine.
Can anyone perhaps provide me with the part number for a new fuel filter?
Best regards, WarLord
pepps Guest
18-10-2004, 19:10 Subject: Diesel filter and the funny spider: What kind of wrench? |
Hello, this is a 13mm Allen wrench, but it also works with a 12mm one if the screw isn't too tight!
WarLord Guest
18-10-2004, 19:16 Subject: Diesel filter and the funny spider: What kind of wrench? |
Well, hopefully they will also have it as a spare part. My car already looks a bit damaged.
But okay, then I'll get a 13mm wrench.
daytrader Guest
18-10-2004, 19:29 Subject: Diesel filter and the funny spider: What kind of wrench? |
while it doesn't actually address the main topic
I always meant it was an im bus and not an in bus, but I guess I was a little off.
siehe also hier: http://de.wikipedia.org/wiki/Inbus
MWeid Guest
19-10-2004, 8:43 Subject: Diesel filter and the funny spider: What kind of wrench? |
I always meant it to say 'I'm' and not 'in', but I guess I was a little off
I feel the same way
Greetings,
Mathias
WarLord Guest
19-10-2004, 18:46 Subject: Diesel filter and the funny spider: What kind of wrench? |
Hm, can someone quickly tell me how to separate the filter from the spider and whether it's a major mess?
joergs Guest
19-10-2004, 19:22 Subject: Diesel filter and the funny spider: What kind of wrench? |
In normal cases, it should come loose. The whole thing shouldn't really be so tightly connected. A little bit of diesel is also leaking out. But a suitable rag helps with that...
