ESP Problems VW Golf 4
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Markus D.
Post17-02-2004, 0:32    Subject: ESP Problems VW Golf 4 Quote
'In my VW Golf 4, 1.9 TDI 85KW, manufactured in 2/2000, the ESP light is constantly on. The diagnostic scan revealed the error '01423 Sensor for transverse acceleration G200, error in the electrical circuit 57-00. According to VW, the transverse acceleration sensor on the steering column should be replaced. This device is only available together with the yaw rate sensor and costs approximately 500€ together. I have read in online forums that these sensors were also available separately until the end of production in 2002 (transverse acceleration sensor for 130€). However, my VW dealer is not aware of this. Does anyone have a VW spare part number for the transverse acceleration sensor alone? These parts are also known to fail. However, I can't find any statements about that here. Thank you icon_question.gif'
Translated on 28-08-2026, 7:39.
mersente
Post25-02-2004, 22:36    Subject: ESP Problems VW Golf 4 Quote
Hello, I've done some research.
There is a standalone lateral acceleration sensor, but only for vehicles with 4Motion. Otherwise, only the combined sensor (lateral acceleration and steering angle in one) is available.
But maybe the individual sensor will work?
1J1 907 638 B Sensor.
To be used with:
1J1 972 793 Retaining clip.
1J1 972 791 B Retaining bracket.
If you've tried it, I'd be interested to know if it works.
Translated on 28-08-2026, 7:41.
BoraVariant
Post01-06-2004, 20:30    Subject: Sensor Defect: Troubleshooting & Repair Guide Quote
My sensor is defective. (Bora, year 2000)
The exact same error message.
How did you fix it? Was it a loose connection, or did you replace the sensor?
Carsten.
Translated on 28-08-2026, 7:42.
diabolo
Post22-09-2004, 13:09    Subject: ESP Problems VW Golf 4 Quote
Where is the sensor located?
Translated on 28-08-2026, 7:43.
BoraVariant
Post26-09-2004, 10:54    Subject: Sensor Position: How to Find & Optimize Quote
The sensor is located beneath the steering column.
I had mine replaced, and it cost over €400 for that piece of junk.
juergen908
Post26-10-2004, 19:26    Subject: Sensor Position: How to Find & Adjust Quote
The sensor is located under the steering column.
I had mine replaced, and it costs over €400 for that piece of junk.
Mine should be ready too.
Same appearance as the author of the post...
I read somewhere else that there's an additional connector attached to the battery, and that...
It can also trigger this error even with a loose fit.
It can happen after a hectic inspection...
For a more precise diagnosis, I need to take it back to the workshop.
If the sensor needs to be replaced, I will keep the old one.
and (in my capacity as an electrician), I'll check what's causing it to fail.
I'll get back to you here.
(I wish I had a car as reliable as my old Golf-II TD again, sigh.)
P.S.:
Unfortunately, I was too afraid of the airbag to remove the sensor myself.
and that he might not protect my wife anymore...
Translated on 28-08-2026, 7:45.
No new posts Golf 5 Problems: Tailgate/Rear Door Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Motion, Year 2013, Problems with ASR/ESP/ABS/Autohold Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF Probleme Golf 6 CR MKB: CBAC Diesel Engine Technology
No new posts Golf 3 AHU - Problems with Turbocharger Pressure Control On-Board Diagnostics (OBD)
No new posts Probleme mit Tempomatsteuerung im Golf IV Transmission, Chassis, Body & Interior
No new posts Golf 5 1.6 FSI Fuel Problems in Heat Gasoline Engine Technology
