Rasergrüning Guest
29-10-2004, 17:34 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
'Hi, the Golf Mk3 was running great until now. The problem is that the preheating light suddenly started flashing, there's no power anymore, and error code 01237 is displayed, which indicates a timing adjustment issue.'
What could it be this time? The posts always only mention the fuel shut-off valve, but nothing about ignition timing adjustment. And there's no fuel visible or smellable in the engine compartment either.
Hoping for a quick recovery so he can run again soon. Best regards, Chriss.
It's not about adjusting the ignition timing; it's about adjusting the ignition angle.
Translated on 18-07-2026, 0:29.
29-10-2004, 17:47 Subject: Re: AFN preheating lamp flashing - error code 01237 - ignition timing issue |
Rasergruening wrote: | | What could it be this time? The posts always only mention the fuel shut-off valve, but nothing about ignition timing adjustment. So, it's not an ignition timing adjustment, but rather an ignition angle adjustment. |
Be careful that Rainer doesn't "teach" you a lesson with the VAGCOM crack -> delete user method... Gruß Ulf
Translated on 18-07-2026, 0:30.
Profile PM Garage |
Joined: 04/12/2002 Posts: 18086 Karma: +797 / -0 Location: St.Gallen 2018 Volkswagen T6
29-10-2004, 17:50 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
You were faster, Ulf...
Everyone has their chance; what are you doing with yours, Chriss?
Where did you obtain your VAG-COM license, and which software version did you purchase?
License code?
Translated on 18-07-2026, 0:31.
Profile PM WWW Garage |
Rasergrüning Guest
29-10-2004, 21:28 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
Hi, I'm not entirely sure what you mean, but I only have a shareware version.
Translated on 18-07-2026, 0:32.
Theresias Guest
30-10-2004, 0:58 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
Hello, I'm not entirely sure what you mean, but I only have a shareware version.
I'd say: Wrong answer...
Translated on 18-07-2026, 0:33.
maverick
Joined: 10/26/2004 Posts: 3 Karma: +6 / -0 Location: Frankfurt
30-10-2004, 6:38 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
.....really awesome,  Geht net, gibt´s net!!!
Profile PM Email |
Max d. Ä. Guest
30-10-2004, 11:59 Subject: AFN glow plug blinking - error code 01237 - ignition timing adjustment |
@rasergrüning
Still clueless?!
Bye.
Max.
