Regardless, the additional
pressure loss caused by the usual constricted intake nozzles is noticeable, and in practice, this loss is practically not recovered on the way to the turbocharger, AFAIK.
The wisdom about the weakest link in the chain, which determines everything, doesn't necessarily apply here -> Removing the restriction from the intake manifold still makes sense.
I can confirm that. I replaced the air intake boot on my AXR engine with a 60mm flexible hose. To do this, I disconnected the clutch pedal switch, and the EGR valve is 'defective.'
The turbo kicks in better below 1800 RPM. The engine responds better to changes in RPM in the lower gears, especially in first gear. Previously, it felt like a torque limiter was engaged in first gear, but that's gone now. If you're not careful and overdo it, the ASR (traction control) will have a hard time because the engine revs up almost like a gasoline engine. The engine also revs higher. You no longer feel the need to immediately floor the accelerator when accelerating because something starts to happen earlier. Everything feels smoother overall.
In the 5th gear, however, not much changes. The maximum speed remains the same.
So, the smaller the step, the more progress you make.
But don't expect anything drastic. The change is small, but it's definitely noticeable.
It's important that the pipe has as straight a run as possible. I also tried using a 70mm plastic pipe with a bend. However, the bend is more of a kink. The resulting turbulence (noticeable by a louder intake noise) likely confused the mass airflow sensor.
Unfortunately, I am missing a diagnostic device (software + laptop) for the measurement trip.
Unfortunately, I am unable to provide any images, as I do not have access to a camera.
