Suche Erfahrungen mit Bosch Aero Wischern | Posts 16+
Go to page: Previous  1, 2
x world one
Post09-11-2004, 10:22    Subject: Quote
Possibly, the paper settings are incorrect.
Apparently, the original VW wiper blades should be installed by a VW dealer because they require a specific angle relative to the windshield. (That's what I heard.)
Did you install the original parts or the retrofit kits?
Spritmonitor
Translated on 17-09-2026, 4:12.
Post09-11-2004, 11:16    Subject: Quote
@ x world
Are you referring to me when you say "wiper incorrectly adjusted"?
There's nothing wrong with the way they're set up; they clean the windshield perfectly, but then they just stir up the foam and spread it back onto the glass.
You can only adjust the angle of the rubber blades, which affects the actual wiping process. I've already tweaked that setting because otherwise, the double edge wouldn't turn over properly.
Translated on 17-09-2026, 4:13.
x world one
Post09-11-2004, 11:27    Subject: Quote
Sure, I meant the angle of incidence to the lens.
It was just an idea that this might possibly be related to something.
Spritmonitor
Translated on 17-09-2026, 4:14.
Post09-11-2004, 11:37    Subject: Quote
Yes, good idea, but it's definitely a "swirl problem" because it's speed-dependent, and it's causing splatters, not streaks (which would indicate insufficient pressure).
christians
Post09-11-2004, 23:01    Subject: Quote
How do Aero wipers perform in the winter?
It bothers me that, under normal conditions, these windshield wipers get blocked by ice on cold nights and then can no longer conform to the shape of the windshield. Manually wiping them clean helps, but it's a hassle, especially when you could theoretically just start driving thanks to the heated windshield.
Gruß Christian
Translated on 17-09-2026, 4:15.
Julian
Post10-11-2004, 15:56    Subject: Quote
I wanted to write this yesterday, but I forgot.
My flat-blade windshield wipers (also known as aero blades) surprisingly work very well on my Audi when driving in heavy snowfall. I never experienced that with the Bosch Twin blades on my previous car (a Golf 4).
However, it's also possible that the 'optimized' aerodynamics of the A4 are to blame, as the standard wipers are even faster there. The Aero wipers simply offer a slightly smaller surface area.
It always annoyed me last winter in Austria when you were forced to stop for the windshield wiper cleaning break: From the balmy 22°C to the freezing -22°C..... icon_wink.gif
Otherwise, the wiping ability and flexibility are perfectly fine, and it wipes very well.
Translated on 17-09-2026, 4:16.
x world one
Post11-11-2004, 10:42    Subject: Quote
I think that Aero wipers ice up less than regular wipers. The problem with regular wipers is that the blade holder can get stuck due to ice and snow buildup. This reduces the pressure on the windshield, resulting in poor wiping. This doesn't happen with Aero wipers.
Spritmonitor
Translated on 17-09-2026, 4:17.
No new posts Bosch ABS/ESP 5.3: Basic Settings & Configuration Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch VP44 pump control unit repair Troubleshooting & Guides
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Aero Upgrade Set Transmission, Chassis, Body & Interior
No new posts Aero Wiper Blades: Retrofit for VW Passat 98 Transmission, Chassis, Body & Interior
No new posts [Poll] OT: Experiences with eBay Transmission, Chassis, Body & Interior
No new posts Bosch Vehicle Pass: What is it? Diesel Engine Technology
