1Z Compression Specs: Does Anyone Know?
macgyver68
Post18-11-2004, 19:28    Subject: 1Z Compression Specs: Does Anyone Know? Quote
Today, while troubleshooting, I started checking the compression, and initially got a reading of 22 bar for cylinder number 4. I'll check the others tomorrow...
Is this still within the acceptable limits?
'ete' translates to 'eat' in English.
When I recently removed the cylinder head, I noticed a dried-up puddle in the fourth cylinder. What is this, and where did it come from?
Hi Manuel,
Translated on 14-08-2026, 6:26.
Post18-11-2004, 19:33    Subject: Compression ratio for 1Z engine - anyone know? Quote
macgyver68 wrote:
Recently, when I removed the cylinder head, I noticed a dried-up puddle in the 4th cylinder. What is this, and where did it come from?
Either the cylinder head gasket is leaking (coolant), or the injector nozzle isn't sealing properly (it's dripping diesel).
Both issues should be resolved before proceeding with further troubleshooting.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 14-08-2026, 6:28.
Post18-11-2004, 22:28    Subject: 1Z Compression Specs: Does Anyone Know? Quote
"If you have the other compression readings, please let me know. 22 bar seems sufficient, as far as I'm aware, the wear limit is around 19 bar. Normally, it should be somewhere between 25 and 30. It's also important that there aren't significant differences between the individual cylinders; the maximum deviation shouldn't exceed 5 bar."
Make sure everything is done correctly when taking measurements.
Translated on 14-08-2026, 6:29.
No new posts Does anyone know about Ardic parking heaters? Transmission, Chassis, Body & Interior
No new posts Opel TD: Questions & Answers / Help Needed Diesel Engine Technology
No new posts 1Z vs. AFN Engine: Differences and Comparison Diesel Engine Technology
No new posts High Idle Fuel Consumption: Is This Normal? On-Board Diagnostics (OBD)
