The outside temperature sensor is showing a reading that is 5 degrees too low
tobi999
Post23-11-2004, 12:18    Subject: The outside temperature sensor is showing a reading that is 5 degrees too low Quote
Dear A6 experts,
My outdoor temperature display has recently been showing a reading that is consistently about 5 degrees too low. Regardless of whether...
It's either cold or warm outside. Can this be adjusted, or do I need a new sensor?
to be installed. 'Regarding the inquiry about Audi, well, that would probably require a new...'
'Let's try it,' but 'we don't have something like that here.'
Thank you for your help.
No new posts Audi A2: Dashboard shows only range Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG 1.8L R4/5V 125hp (92kW) Naturally Aspirated Gasoline ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Outside temperature sensor Electrical Systems, Vehicle Electronics, Multimedia
No new posts Fan starts at 97.8°C - Is this normal? Diesel Engine Technology
No new posts Injection Timing: 17 Degrees BT - Is It Safe? Diesel Engine Technology
No new posts JMA: Better Performance at -13°C? Diesel Engine Technology
