Eberspächer installation documentation
dieselkugel
Post08-12-2003, 13:37    Subject: Eberspächer installation documentation Quote
Hey guys,
I received a universal installation guide from the manufacturer for my Eberspächer auxiliary heater. Only Eberpächer modified the heating systems at some point.
Unfortunately, my documentation only shows the new type.
I'm now looking for these downloads for the older model (the hotline isn't helping).
It's actually only about the permissible installation positions of the heating system.
I have a D4WSC system (all pumps are integrated into the heating system).
Does anyone happen to have a copy of the installation manual lying around?
w123diesel
Karma: +7 / -1   Thank you, like it!
Post17-12-2003, 10:30    Subject: Eberspächer installation documentation Quote
I recently had a stand heater from Eberspächer (the same one as you) installed.
The installer told me that the only permissible installation orientation is vertically, so that the water hose connections point downwards.
If necessary, you can also call a Bosch service center near you; they install Eberspächer auxiliary heaters and should be able to help you.
http://www.bosch-service.de/
Jürgen
effsechs
Post21-11-2004, 11:49    Subject: Eberspächer installation documentation Quote
Hello!
The SH unit is installed vertically, with the water connections facing downwards.
Post21-11-2004, 19:43    Subject: Eberspächer installation documentation Quote
I dare to doubt that. If the water connections are facing downwards, how does the venting work?
cetano
Avatar-cetano
Post24-11-2004, 13:57    Subject: Eberspächer installation documentation Quote
If this opportunity is still available.
There are exactly 3 built-in options.
The heater is installed, and the exhaust and intake pipes point downwards (normal position).
2. The heater is rotated from this position (around the axis of the long mounting screw) so that the water inlet now points downwards.
3. The heater is mounted horizontally, so that the cable entry and the bleed screw are located at the top.
No other built-in installations are permitted.
(from Hydronic D4WSC manual)
Kfz-Prüfstelle des TÜV Rheinland/FSP Saalfelder Höhe in Thüringen im grünen Herzen Deutschlands.
Wir lieben Diesel, vor allem alte..
Sommer: Oldtimer W124 2,5 Saugdiesl 90 PS Bj 87, Winter: Golf4 4Motion TDI AGR
Back to top Profile PM Email
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Airtronic D2 Defective: Troubleshooting Smoke Issues General Tips
No new posts Webasto Thermo Top T DW50 Installation Guide A6 2.5 TDI Transmission, Chassis, Body & Interior
No new posts Eberspächer Auxiliary Heater Transmission, Chassis, Body & Interior
No new posts Airtronic D2: Eberspächer Diesel Heater On-Board Diagnostics (OBD)
No new posts Eberspächer D4WSC Problems: Troubleshooting & Help On-Board Diagnostics (OBD)
