"I'm experiencing the same problem. Both front tires are wearing down very unevenly on both shoulders. Everyone I've talked to so far has told me that I'm probably driving with too little tire pressure. However, that can't be the case, as I always drive with approximately 2.5 bar. Also, there are no visible signs of damage to the suspension or any other components. It would be really great if someone had some insight into this. I'm using the standard tire size 185/60 R14 from Continental, both summer and winter tires. Could it be related to the brand? Although, I've actually been quite satisfied with them so far."
I have the same problem. Both front tires are wearing down very heavily on both shoulders. Everyone I've spoken to so far has told me that I'm driving with too little pressure based on the tire pattern. However, that can't be the case, as I always drive with approximately 2.5 bar. ...
