Exhaust gas recirculation (EGR) specifications for the AFN Golf 3
dj1
Post01-06-2004, 11:55    Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 Quote
I want to do the exhaust gas recirculation icon_cool.gif.
So, just screw a stainless steel plate onto the manifold.
Does anyone have a sketch with dimensions for such a plate?
It would be great, otherwise I would have to measure everything painstakingly.
Thank you.
DJ
Post01-06-2004, 12:01    Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 Quote
Just buy a coloring book and trace the designs.
Or, quite brazenly, have it shown to you, copy it, and DON'T buy it icon_twisted.gif.
donalexo
Post01-06-2004, 12:10    Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 Quote
Hello dj1!
I would definitely buy a gasket and use it as a template for the sealing plate. Finally, you need a second gasket between the sheet metal and the flange icon_wink.gif.
Otherwise, it cannot be guaranteed that your connection is secure. Depending on the installation orientation, you might experience leaks either on the charge air side or the exhaust side.
Alex.
Touran 1.9 TDI, EZ 09/2004
dj1
Post01-06-2004, 12:18    Subject: You're welcome Quote
Thank you!
I'm going to get a poem and copy it out!
DJ
moriaty
Post25-11-2004, 1:25    Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 Quote
Hey, can you explain to me why you're doing this? What's the point? And what's the exhaust gas recirculation (EGR) valve for? I had a power loss on my AFN 110hp engine. I unscrewed the hose from the valve, and then it ran better than before. Why is that? How does it work? What's the purpose?
Post25-11-2004, 2:12    Subject: Exhaust gas recirculation (EGR) specifications for the AFN Golf 3 Quote
@ moriaty
Have you read "The Little Fat Cupcakes"?
I don't think so, because if you had, you would have searched for "AGR" or "exhaust gas recirculation" and found so much information that you could give a presentation about it yourself.
And by the way:
Why are you messing around with parts of the car that you don't know what they're for?
That would be too expensive for me!
(P.S. I don't expect a response - just use a search engine.)
Thank you.
moriaty
Post26-11-2004, 13:11    Subject: Hey, I'm new to your site, sorry. Quote
Yes, thank you.
My search function wasn't working, or maybe I was just too dumb to use it. But in the meantime, I now know pretty accurately how the EGR system works and why. I've never owned a diesel before. And I also know why I would want to seal it off. Through my own thinking and maybe some experimenting, I've saved a lot of money and time, because all the mechanics were looking for the problem in other places. They all had no idea. First, I checked the timing, then the turbocharger, then the catalytic converter, etc., all based on the mechanics' suggestions. It was only a Volvo owner who pointed me in the right direction. And in my books, there was nothing about the function and operation of the exhaust gas recirculation system.
I have to commend this website. It has provided me with a lot of valuable information, especially the information I was looking for. I will definitely use it again in the future, okay?
P.S.: Whoever finds a spelling mistake can keep it.
No new posts {ENGINE_TYPE} Dimensions and Wear Limits Technical Data
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts Exhaust gas recirculation: function and problem areas Technical Articles
No new posts Abgasrückführung Regeldifferenz beim AAT Diesel Engine Technology
No new posts Vacuum Hose Size: Dimensions & Specs Diesel Engine Technology
No new posts Dimensions for adjustment or locking ruler for camshaft Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
