VW Golf 4 Inspection Interval: 2002 Model
wetec
Post27-08-2002, 12:36    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
hi,
I'd like to know how to check the remaining mileage until the next service on my 130hp TDI-PD engine.
Vehicle data:
-96kW TDI PD
-6gang
- MFA
-GRA
As described in the manual (pressing the lower button of the MFA switch for longer than 2 seconds), it doesn't achieve the desired result!
'Thank you.'
Translated on 25-10-2026, 11:43.
Gremlin
Post27-08-2002, 17:18    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
That doesn't work in the Octavia either.
While we're on the subject:
combination instrument
1U0 920 821 F VDO V08
softcoding 23112
adaptation channels:
47 = 'liter amount in 100km' (63)
It seems to be related to the interval, and the values are increasing daily.
Sure, I can help you with that. Here is the translation of the German text:
'Just what do they mean, how are they interpreted?'
As for hints, here are a few things to keep in mind when interpreting the meaning of a text:
* **Consider the context.** What is the overall topic of the text? What is the author's purpose?
* **Pay attention to the language.** Are there any words or phrases that stand out to you? What do they suggest?
* **Look for patterns.** Are there any recurring themes or ideas?
* **Think about the author's perspective.** What is their point of view? How might that influence their writing?
By considering these factors, you can begin to understand the meaning of a text and how it is interpreted.
CU Gremlin.
Translated on 25-10-2026, 11:45.
wetec
Post28-08-2002, 7:08    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
I'm afraid I don't know either!
On a new A4, there's an extra 'service' button that, when pressed, displays the remaining mileage until the next oil change.
I'm also looking for something like that for my Golf.
Translated on 25-10-2026, 11:46.
Michael II
Post28-08-2002, 7:27    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
It is likely a confusing term used by VAG-COM.
Channel 47 represents the rust entry, while channel 48 indicates oil wear.
Tschüss
Michael II
Gremlin
Post28-08-2002, 15:01    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
Do you have any further explanations about that?
or what formulas are used to calculate the service interval?
CU Gremlin.
Translated on 25-10-2026, 11:47.
Michael II
Post28-08-2002, 15:37    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
Unfortunately, I am not familiar with the exact algorithm. More information can also be found in the error database.
"Some additional information:"
Channel 43.
Upper limit for the distance to the next inspection.
Step size: 100 km.
Channel 44.
Upper limit for the time until the next inspection.
Step size: 1 day.
Channel 45.
Oil quality of the filled engine oil:
Vehicles with fixed maintenance intervals (Part No.: QG0 and Part No.: QG2):
Input value: 00001
Vehicles with gasoline engines and flexible maintenance intervals (PR number: QG1):
Input value: 00002
Vehicles with a 6-cylinder diesel engine and flexible maintenance intervals (part number: QG1):
Input value: 00003
Vehicles with diesel engines and flexible...
Maintenance intervals (PR number: QG1):
Input value: 00004
Channel 40.
Distance traveled since the last inspection.
Step size: 100 km.
Channel 41.
Time elapsed since the last inspection.
Step size: 1 day.
Channel 46.
Fuel consumption (gasoline engine only).
Step size: 1 liter.
Channel 47.
Exhaust system (for diesel engines only).
Step size: 100 km.
48 Oil wear (diesel engine only)
Step size: 100 km.
Tschüss
Michael II
Translated on 25-10-2026, 11:49.
Gremlin
Post28-08-2002, 20:22    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
'Thank you!'
CU Gremlin.
Translated on 25-10-2026, 11:52.
Varianti
Post29-08-2002, 7:06    Subject: VW Golf 4 Inspection Interval: 2002 Model Quote
Channel 46.
Step size: 1 liter.
Can you estimate the mileage of a used car based on this value, assuming an average fuel consumption?
Or is channel 46 something completely different?
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Problems with the Main Control P... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Valve for VW Golf IV 96kw TDI-PD Diesel Engine Technology
No new posts Inspection Interval Data On-Board Diagnostics (OBD)
No new posts Fuel Return Valve Location: AVF TDI PD (2002) Diesel Engine Technology
No new posts VW Golf PD, 150 hp, first registration 03/01 Diesel Engine Technology
