Golf 3 TDI AFN ESP: Specs & Info
vagtuning
Post08-12-2004, 19:02    Subject: Golf 3 TDI AFN ESP: Specs & Info Quote
'My friend's fuel injection pump was broken. Now he got one from a '96 AFN model for a cheap price, but his engine is a '94 1Z. Will the pump work if he installs it?'
Does anyone know?
Translated on 29-10-2026, 4:20.
Post08-12-2004, 20:08    Subject: Golf 3 TDI AFN ESP: Specs & Info Quote
It depends on whether the old pump used a potentiometer or operated inductively. 94 is the exact threshold. If the old pump was inductive, it should work, but then without the required approval certificate (ABE).
The search function should help you understand the differences and distinguishing features.
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 29-10-2026, 4:21.
turgumu
Post08-12-2004, 20:35    Subject: Interlocking Systems: When Both Have Them Quote
If the old pump has an inductive control sensor, then the old, good 1Z injector will run, and even perform better than before, due to the higher injection pressure.
Translated on 29-10-2026, 4:22.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post08-12-2004, 22:14    Subject: Golf 3 TDI AFN ESP: Specs & Info Quote
Wasn't there also different types of connectors and pin configurations?
If both pumps were to have a flow control device, then the old, reliable 1Z would run, even better than before, due to the higher injection pressure
Why should the fuel injection pressure be higher?
It's just a 10mm plunger pump piston.
And the nozzle opening pressure will definitely not change.
B.Eng (FH) u. KFZ Meister
Translated on 29-10-2026, 4:23.
Post09-12-2004, 10:22    Subject: Golf 3 TDI AFN ESP: Specs & Info Quote
Steffarn wrote:
If both pumps were to have a flow control device, then the old, reliable 1Z would run, and even better than before, due to the higher injection pressure
And the opening pressure of the nozzles will certainly not change.
Okay, but the impeller (?) is shaped differently than on the 1Z model.
Steeper "pressure flanks" cause the distributor piston to reach a higher speed at the same rpm, resulting in a higher flow rate and higher injection pressure.
AFN nozzles tend to compensate for this by having larger bore diameters.
Translated on 29-10-2026, 4:24.
Jan03
2010 Volkswagen Polo
Post10-12-2004, 21:09    Subject: Golf 3 TDI AFN ESP: Specs & Info Quote
I've had an AFN ESP installed in my car for three months now, and it makes absolutely no difference! The engine behaves the same, the performance is the same, the engine sound is the same, and the fuel consumption is the same.
Unfortunately, the jerking is now starting to appear. Even with a 1Z engine, you can't be sure with an AFN-ESP (so it's really a software issue in the control unit). According to the previous owner, the pump was replaced at around 120,000 km. However, based on the jerking, it's probably closer to 220,000 km. icon_evil.gif
/Jan
Translated on 29-10-2026, 4:26.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Golf 3 TDI: Install 6-Speed Golf 4 Transmission Diesel Engine Technology
No new posts Golf 3 Instrument Cluster in Golf 2 Dashboard Transmission, Chassis, Body & Interior
