datsun Guest
11-12-2004, 16:22 Subject: Raise Vehicle with Gas Shock Absorbers? |
Hello everyone,
I'm currently working on installing a sports suspension kit for my Datsun.
Could it be that installing gas pressure struts is the only way to raise the vehicle by 1-2 cm?
Previously, only oil pressure dampers were installed. The piston rod never had a tendency to extend. With the new ones, each damper lifts the car by about 20 kg.
Will this effect wear off?
Greetings.
Rainer.
Translated on 11-09-2026, 7:07.
Forenheini Guest
11-12-2004, 17:54 Subject: Raise Vehicle with Gas Shock Absorbers? |
Yes, that's correct, and no, the effect doesn't diminish or only diminishes slightly.
Before I talk for too long... Click
Translated on 11-09-2026, 7:08.
