Golf 5 TDI 170 PS laut Tacho nur 215 ?? | Posts 32+
Go to page: Previous  1, 2, 3
Gremlin
Post21-12-2004, 20:29    Subject: Quote
So, THIS is a standard 1.8T 150hp engine in a Passat Variant...
What would likely happen to the maximum speed if you added 20-30 horsepower?
Exactly... nothing... unless you push the machine too hard.
CU Gremlin.
Translated on 21-08-2026, 5:06.
Avatar-Jan6K
Post22-12-2004, 14:01    Subject: Quote
It's a shame that the MFA (Multi-Phase Adapter) isn't visible in the picture... There must be some kind of monstrous vortex swirling around inside the tank.
January.
1Z5 CFHF / AHB H4D
Translated on 21-08-2026, 5:07.
Gremlin
Post22-12-2004, 15:25    Subject: Quote
19.6 l / 100km icon_twisted.gif
Average speed: 176 km/h.
from the Austrian border via the A3 motorway to just after the Württemberg-Baden state border.
Values include a 35km stretch of country road driven at a steady 100 km/h, and in Nuremberg, only 20 km/h over the speed limit.
CU Gremlin.
Translated on 21-08-2026, 5:08.
Post22-12-2004, 15:30    Subject: Quote
Hm, the noise dampening around the tank must be at least as thick as a high-end CR motor casing. icon_razz.gif
Translated on 21-08-2026, 5:09.
Gremlin
Post22-12-2004, 15:35    Subject: Quote
Hmm, the noise dampening around the tank must be at least as thick as a high-end CR motor casing. icon_razz.gif
Oh, come on...
At that speed, you could bite me and I wouldn't even notice.
concentration rules.
Okay, let's stop the off-topic conversation.
CU Gremlin.
Translated on 21-08-2026, 5:10.
Post22-12-2004, 15:46    Subject: Quote
The maximum speed values for the G 5 have significantly worsened compared to its predecessors. The G 3 GTI with 85 kW had a stated top speed of 196 km/h, and the G 4 with 85 kW was rated at 195 km/h. In contrast, the G 5 with 85 kW is now only specified at 192 km/h, which is a consequence of its van-like high roof.
Looking at the top speed figures for the G5 TDI with 103 kW, which was initially stated as 203 km/h but later increased by VW to 205 km/h (the same value as the 96 kW G 4...), it all makes sense. Good examples of the G 3, like mine, could also reach a top speed of around 205 km/h with a good run. If the tuner couldn't increase the Vmax (as mentioned before, regarding the rated RPM at Vmax), then these values are somewhat plausible.
Furthermore, the maximum speed values of the current A3 are not comparable to those of the G 5, as the A3 has a flatter, more aerodynamic design, as evidenced by its maximum speed of 207 km/h with the same 103 kW engine.
Translated on 21-08-2026, 5:12.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J Doku: Clicking Noises (Up to KW 16/98) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car Shakes at 160 km/h: Sudden Jerk, No Power? Diesel Engine Technology
No new posts VW Golf 4: Replace Analog Speedometer with FIS Display Transmission, Chassis, Body & Interior
No new posts Golf IV ALH: 0.205 Injectors from ASV - Compatibility? Diesel Engine Technology
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
