AFN: Initial Problems and Challenges
TDIMANU
Post01-01-2005, 14:07    Subject: AFN: Initial Problems and Challenges Quote
Hey guys,
I'm having the following problem!
I have a problem with the automatic fuel mixture system (AFN) in my third-generation Golf. When I start it in the morning at 0°C, it starts perfectly fine. However, once it's warmed up, it's very difficult to start; I have to engage the starter for about 5-8 seconds before it will turn over.
What could be the reason for that?
So, we're having some very significant warm-start issues...
I have already exchanged the following:
I replaced the fuel injection pump, adjusted the timing advance two days ago, and replaced the water temperature sensor on the cylinder head. What else could be causing this problem?
What would you say?
Please help me because this problem is very annoying. icon_smile.gif It's quite frustrating to have to wait so long all the time.
Manu.
Translated on 14-08-2026, 19:51.
Post01-01-2005, 14:55    Subject: AFN Issues: Troubleshooting and Solutions Quote
TDIMANU wrote:
What would you say?
1. Check all warm start options from the "Start Problems" article.
2. Ask again with the results.
Translated on 14-08-2026, 19:53.
Julian
Post01-01-2005, 17:08    Subject: AFN Issues: Troubleshooting and Solutions Quote
Please do not provide solutions that repeatedly cover the error image through technical articles and forum searches. Thank you. icon_smile.gif
Translated on 14-08-2026, 19:54.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil consumption in 2.0 TSI engines: A break-in issue? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Startup Problems: Common Issues & Solutions Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Problem beim Ausbau der ESP VP37 beim AEL-Motor (A6 2,5 TDI) Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
