Hello!
I also once temporarily disconnected the EGR hose on my Ruckel-AJM engine (+ sealed it) and voluntarily reconnected it after a short time.
While the engine felt more powerful and ran subjectively better, but:
'The engine was running unevenly at idle, and the mass airflow sensor (MAF) values were already incorrect at idle, and even more so at full load. As far as I know, the turbocharger boost control system has been improved/made faster.'
Hmm, is that normal? My EGR valve is closing properly. I cleaned it with brake cleaner beforehand and checked it for leaks. Could this possibly be a clue related to my misfires? Currently, I'm looking for the cause of the misfires in a different direction. https://community.dieselschrauber.org/en/viewtopic.php?t=7876
I've already tried everything possible, but nothing seems to really work. I've also searched all sorts of forums and the internet, but unfortunately, with no luck!
