21-01-2005, 9:17 Subject: Tool durability test: Does it last? |
Since I want to work on the engine, here in the engine forum:
I have a 1/4-inch torque wrench (up to 30 Nm).
The 3/8 inch drive wrench provides up to 100 Nm of torque.
Okay, I've now purchased the adapters shown in the picture, but especially the 3/8" to 1/2" adapter doesn't seem to convey much torque.
Has anyone here had any experience with these things? Do they last a long time, or do they tend to break easily?
(Background: I only have 1/4" and 1/2" drive bits – all from Proxxon, and a few specialized sockets from Gedore.)
| Description: |
| zwei Proxxon Adapter, die hoffentlich halten |
| File size: |
61.29 KB |
| Viewed: |
1042 times |
Translated on 20-08-2026, 21:06.
Profile PM Garage |
Jay_Dee Guest
21-01-2005, 9:21 Subject: Tool durability test: Does it last? |
Do you want to know now whether Proxxon uses good quality components, or whether you can use your construction to loosen central axle nuts?
I have had very good experiences with Proxxon products, although the ratchets with the tilting lever shifting mechanism are a poorly designed flaw.
However, the Nuesse products are quite durable – much more so than comparable generic or unbranded products!
Translated on 20-08-2026, 21:08.
wutz Blaumann
Joined: 08/13/2004 Posts: 247 Karma: +11 / -1 Location: BRA 2006 Seat Leon Free account, no CAN development support
21-01-2005, 11:23 Subject: Tool durability test: Does it last? |
I've had very good experiences with Proxon so far. I haven't been able to identify any disadvantages compared to tools from brands like Gedore or Hazet.
To be absolutely sure, I would simply try it on a different screw (one that's not critical for torque). That way, you can be certain whether the adapter holds properly. If it's from Proxon, it should work fine.
Translated on 20-08-2026, 21:09.
Profile PM Garage |
chris11 Profi-Schrauber
Joined: 10/02/2002 Posts: 326 Karma: +3 / -1 Location: Münster
21-01-2005, 11:59 Subject: Tool durability test: Does it last? |
If they actually used the promised chrome steel, your 1/4-inch ratchet will likely break down sooner than this construction. And with the normally used through-handle design, the 1/2-inch part shouldn't fall apart either.
Christian.
Translated on 20-08-2026, 21:10.
21-01-2005, 19:07 Subject: Tool durability test: Does it last? |
Thank you for your help.
I just realized that I already have the  3/8 to 1/2 piece.
That's just the standard type of clamp for a 1/2 inch size – well, if it doesn't hold now, I have another one.
The 30 Nm torque for the turbo screws on the JX was more than sufficient.
Translated on 20-08-2026, 21:11.
Profile PM Garage |
