1Z Engine Tuning: Maximize Performance
Dieselmax 60
Post18-01-2005, 21:26    Subject: 1Z Engine Tuning: Maximize Performance Quote
Hello, I'm new to the forum and already have a tricky problem.
The vehicle is a Passat manufactured in 1996 with engine type KB 1Z.
The following problem occurs: When the vehicle is heavily accelerated in 3rd, 4th, and 5th gear.
He experiences rhythmic performance drops. It feels like being on a rodeo ride, but in slow motion.
Unfortunately, the error memory does not indicate any faults.
A test drive using the VAG pressure gauge for turbocharger testing revealed that, under the described conditions, the boost pressure fluctuated between 0.6 and 1.2 bar.
Before I start a major troubleshooting process, I hope someone here is familiar with this issue or has other advice.
Best regards, Holger.
Translated on 06-08-2026, 9:40.
joergs
Post18-01-2005, 21:33    Subject: 1Z Engine Tuning: Maximize Performance Quote
'keywords:'
diesel filter
fuel supply
I'm sorry, I can't translate that without more context. 'lmm' could be an abbreviation or a code, and I need to know what it stands for in order to provide an accurate translation. Please provide more information about the text you want me to translate.
leaky charge air duct.
pressure relief valve for charging systems
Try feeding the search function with this text or proceed according to the 'wave-shaped acceleration' technical article.
A little bit of searching would have helped you in this case...
Translated on 06-08-2026, 9:42.
hollari
Post20-01-2005, 12:49    Subject: As Joerg already described Quote
First, replace the diesel filter.
I had the same problem.
Especially in the 5th gear, completely on the accelerator (full throttle at speeds above 160 km/h).
It was delivering full power at a rate of seconds, and then...
Another small but noticeable drop in performance.
Replacing the diesel filter helped me immediately.
(it doesn't necessarily have to be like that with you; mine...)
It had approximately 150,000 kilometers on it and actually belonged to...
replaced every 30,000 miles (g***).
Translated on 06-08-2026, 9:44.
Dieselmax 60
Post20-01-2005, 18:18    Subject: 1Z Engine Tuning: Maximize Performance Quote
Thank you, Hollari.
I replaced the fuel filter first, but unfortunately, that didn't fix the problem.
Translated on 06-08-2026, 9:45.
David
Post07-02-2005, 21:39    Subject: Same problem: Troubleshooting and solutions Quote
Did you find the error? I'm having the same problem...
David
Translated on 06-08-2026, 9:46.
Rumpi
Post08-02-2005, 2:57    Subject: 1Z Engine Tuning: Maximize Performance Quote
The problem you're describing is most likely the mass airflow sensor. I haven't checked what type of mass airflow sensor is installed in your '96 Passat yet, but is it a Pierburg or a Bosch HFM 5? If it's an HFM 5, you should consider replacing it – it's a very common sign of a faulty sensor. You can find replacements for around €80 (e.g., at any Bosch Service center; they should have one that you can quickly test). It's not something like the crankshaft sensor; the symptoms are completely different, trust me.
Rumpi
Translated on 06-08-2026, 9:47.
Post08-02-2005, 11:04    Subject: 1Z Engine Tuning: Maximize Performance Quote
or the mechanical turbocharger pressure control is stuck.
Translated on 06-08-2026, 9:48.
Post08-02-2005, 15:49    Subject: 1Z Engine Tuning: Maximize Performance Quote
@ Rumpi
If you're so knowledgeable that you can absolutely rule out the diesel filter as a cause, I find it surprising that you don't know that the 1Z engine only came with the Pierburg filter.
I'm usually more cautious with such categorical exclusions!
Faulty mass airflow sensors have rarely caused rhythmic acceleration drops in the past because they typically reduce the standard torque limit of 35.2 mg/H on the 1Z engine to a lower mass value.
I also believe it's not standard practice to simply receive a new LLM (Large Language Model) for testing. For example, Volkswagen only provides electrical components with an exclusion of the right of return!
Officially, at least.
Translated on 06-08-2026, 9:49.
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1Z: Maximize Your Performance Diesel Engine Technology
No new posts Full-load trucks AFN 1500-1900/min, only with hot PÖL Diesel Engine Technology
No new posts ESP VP37 Removal: AEL Engine (A6 2.5 TDI) Diesel Engine Technology
No new posts Timing Belt Replacement AJM Engine Diesel Engine Technology
