ESP Light On While Driving: What to Do?
Robbin
Post19-02-2005, 11:51    Subject: ESP Light On While Driving: What to Do? Quote
I'm having a small problem again.
'My ESP warning light comes on while driving without any apparent reason. When I turn on the ignition, the warning light goes out after about 3 seconds, but then comes back on after about 15 minutes of driving and only turns off when the ignition is switched off. If I start the engine, the light is off, but then comes back on after some time. The ABS still functions, but the ESP is not active while the light is on.'
Does anyone know what might be causing this?
Robbin.
Translated on 01-11-2026, 6:04.
Post19-02-2005, 11:57    Subject: ESP Light On While Driving: What to Do? Quote
It's best to first inquire with the ESP/ABS system why its warning light is illuminated: read the error codes.
It should also indicate if, for example, one of the wheel speed sensors is not providing a proper signal.
Translated on 01-11-2026, 6:05.
Robbin
Post19-02-2005, 12:07    Subject: ESP Light On While Driving: What to Do? Quote
Are the same sensors used for ABS and ESP, or are there separate sensors? I suspect there might be a grounding problem with the switches.
Robbin.
Translated on 01-11-2026, 6:06.
Post19-02-2005, 12:34    Subject: ESP Light On While Driving: What to Do? Quote
My brother had a similar problem with his SEAT. The solution was the same as it is here:
(bad battery connection)
@Rainer
Interestingly, the error memory was empty.
Steffarn
Avatar-Steffarn
2003 Audi A4 Avant
Post20-02-2005, 0:32    Subject: ESP Light On While Driving: What to Do? Quote
Robbin wrote:
Are the same sensors used for ABS and ESP, or are there independent sensors installed? I suspect there might be a grounding problem with the switches.
Robbin
Each wheel has only one sensor!
A car equipped with ESP only has one additional hydraulic unit and a steering angle sensor.
B.Eng (FH) u. KFZ Meister
Translated on 01-11-2026, 6:07.
Post20-02-2005, 0:54    Subject: ESP Light On While Driving: What to Do? Quote
This could also be due to the combination sensor for acceleration and rotational rate, installed by ESP, located below the steering column. If the error memory indicates this, it will be quite expensive: the part costs over 500 euros icon_eek.gif.
Translated on 01-11-2026, 6:08.
No new posts Golf 5 Gearbox: Won't Shift Gears While Driving Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 engine cut out while driving, and... Diesel Engine Technology
No new posts AHF Failure: Troubleshooting & Solutions Diesel Engine Technology
No new posts Car Engine Failure: What to Do? Diesel Engine Technology
No new posts Shaky Ride at 70 mph: Causes & Fixes Transmission, Chassis, Body & Interior
