Eberspächer B5Wsc Not Working: Troubleshooting
atomicfan
Post16-01-2005, 23:11    Subject: Eberspächer B5Wsc Not Working: Troubleshooting Quote
Unfortunately, I'm having a problem with my Eberspächer heater.
It simply won't start anymore.
I intended to start it on December 24th, but it wouldn't start. It also wouldn't start on December 26th. However, after driving for about an hour, it started perfectly and ran flawlessly.
Since then, I've tried several times, but it simply won't run, or rather, it simply won't start.
The problem is that it doesn't start at all; it doesn't draw anything in or do anything.
I'm connecting it via TP 5, and it shows that the heating is running and counts down the time, but the heating isn't actually doing anything.
Does anyone have a clue or a tip as to what might be causing this, or how I could get the heating working again?
Eberspächer service said they could only read the error codes, but that would require removing the bumper. They suspect a faulty control unit.
It's probably locked now, after I tried to start the heating system several times. I've checked the fuses, relays, etc., and everything seems to be okay. What else can I do?
"Or, how can I figure out what's broken? I'm just surprised that the heating system isn't doing anything at all, not even drawing in fuel or starting up, it's just completely unresponsive."
Translated on 04-10-2026, 19:35.
schweinetransporter
Post26-02-2005, 18:14    Subject: Eberspächer B5Wsc Not Working: Troubleshooting Quote
What kind of car do you have?
Maik.
Translated on 04-10-2026, 19:36.
atomicfan
Post26-02-2005, 18:36    Subject: Eberspächer B5Wsc Not Working: Troubleshooting Quote
I have a Golf IV.
The problem seems to have been resolved.
A pin has broken off inside the connector, which is why there was a constant power supply issue. Let's see if it works now with a new, used control unit.
Translated on 04-10-2026, 19:37.
No new posts Touran GRA not working after TCU replacement Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Eberspächer Heater Diagnostics: Troubleshooting Guide Troubleshooting & Guides
No new posts Airtronic D2 Defective: Troubleshooting Smoke Issues General Tips
No new posts Preheating system not working Diesel Engine Technology
No new posts Cruise control not working (1Z) On-Board Diagnostics (OBD)
No new posts DPF emergency regeneration not working Diesel Engine Technology
No new posts Windshield Washer Fluid Warning Not Working Transmission, Chassis, Body & Interior
