Hello.
I'm having a very strange problem with my 1Z engine, and I don't know what to do anymore.
and I hope someone here can help me
I've also already used the search function, but unfortunately without success.
Okay, so here's my problem:
When I'm stopped at a traffic light and occasionally press the accelerator hard, everything is fine up to 4000 RPM.
As soon as I exceed 4000 RPM, the engine almost dies, and when I put it in the...
I can't see anything in the rearview mirror anymore, just smoke, and it's very dark smoke!!!???!!!
Okay, hier ist die Übersetzung:
"Or, for example, when I'm driving on the highway and accelerating, it reaches a speed of up to 130 km/h."
It runs reasonably well, but it cuts out at 130 km/h. If I then press the accelerator, it will go up to 150 km/h after about 10 seconds, but then it cuts out again and it simply won't accelerate any further.
If I pump it again with the gas for 10 seconds, it goes up until 170, and then it stops again
. After another 10 seconds of pumping, it goes up to 190, where it stays for a while, and eventually, the top speed drops down to about 175 !!!???!!!
Does anyone know about this problem
Okay, I wanted to add that the engine has a chip, and I also installed a new mass airflow sensor (MAF). When I first bought the car, and even after replacing the MAF, I thought the problem might be the chip. However, when I remove the chip, the car runs even worse, and the problem persists.
I hope someone can help me here
Thank you in advance.
