VAG TDI Tuning: Diagnostics & VW 5051
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post16-09-2002, 13:10    Subject: VAG TDI Tuning: Diagnostics & VW 5051 Quote
Hi fans,
I read the following text in another forum:
"The quick brown fox jumps over the lazy dog."
I've found a way, thanks to my colleagues, to increase the power of a TDI engine a little bit more without using an additional chip or module. This involves modifying the engine data in the engine control unit using a VAG tester, specifically the VAS 5051. This can only be done at a reputable car dealership. I want to point out that the warranty may be voided. Please inquire beforehand. While it doesn't result in a significant increase in horsepower, it does noticeably improve the torque.
Okay, enough talking, here's the instructions:
1. Have the error code read.
2. If there are any errors in the system, have them resolved beforehand.
"If a tuning box is installed, it must be removed beforehand, as it would otherwise produce incorrect data. It can be reinstalled after the process is complete. The tuning described here may also be a factory setting. VW has set the value to the middle, and here it is only slightly increased. There are no negative effects other than a slight increase in soot emissions. According to a VW service technician, there is no risk. I have not experienced any damage or loss of performance so far."
4. Now, here's the tuning scheme:
TDI tuning for all TDI engines except those with a "Pumpe-Düse" (injection pump) system.
It is very important to save the old values beforehand in case it is necessary to revert the process.
01 Engine
Login 12233
Channel 01 32784 Max Values (these are sliders that you can move up and down!).
Channel 02 33638 Max Values.
Now, the time has come. Your TDI now has a bit more power.
The effect: A bit more torque and better acceleration. With the TDI automatic transmission and an additional module, the torque remains the same, along with the corresponding power output. Those who have had it installed are very enthusiastic.
************************Quote End
Kann mir das jemand in Klartext übersetzen ? Was genau wird da modifiziert ? Toleranzbereich Ladedruck ? Injection volume?
I have absolutely no idea what's going on.
Greetings.
Translated on 23-09-2026, 7:27.
Post16-09-2002, 13:26    Subject: VAG TDI Tuning: Diagnostics & VW 5051 Quote
Hello Jens,
benutze bitte die Suchfunktion mit dem Stichwort 'Adaption'.
Nothing magical is being done here, and you can also skip disassembling the box because it's pointless.
However, based on my experience, these modifications only result in very modest gains in power/torque.
If I remember correctly, the adjustment range for the injection volume on my AHF device is between 1.6 and 3.2 mg per injection. The maximum volume is likely 51 mg per injection.
Therefore, the additional power would be 0.8 / 51, which is 1.57%.
With that, the engine, which originally produced 110 standard horsepower, actually produced 111.7 horsepower. icon_lol.gif
Channel 2 only adjusts the idle speed, which is a bit of a hassle.
Translated on 23-09-2026, 7:32.
BlauBaer
Post18-09-2002, 16:24    Subject: VAG TDI Tuning: Diagnostics & VW 5051 Quote
I found a company online that offers the same service: tuning via the diagnostic interface.
www.****4*****.de
I think there's probably a bit more to it than just a 1.57% performance increase icon_smile.gif.
But I also don't know exactly what they're doing there, unfortunately.
Oh yeah... and I've also tried using the search function to find something, but I have no idea which values to set... and I don't want to just experiment randomly.
Translated on 23-09-2026, 7:34.
Animalking
Post18-09-2002, 17:03    Subject: VAG TDI Tuning: Diagnostics & VW 5051 Quote
I was just on the Chip 4 power page!
I don't think they seem very reliable.
'They're completely crazy! They're charging 599 euros for tuning via the diagnostic interface! I think you can adjust the performance somewhat through adaptation, but nobody really knows which settings are good and which aren't, because everything is very rough.'
'Furthermore, why shouldn't this apply to a PD (Personal Data) situation?'
Translated on 23-09-2026, 7:35.
Post18-09-2002, 17:27    Subject: VAG TDI Tuning: Diagnostics & VW 5051 Quote
We've discussed this topic before, but the fact that the same interface is used doesn't say anything about the type of tuning involved!
Please use the search function.
Translated on 23-09-2026, 7:36.
No new posts 10Cent Tuning Technical Articles
No new posts Tuning: Intake & Intercooler - Optimization Guide Technical Articles
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts Boost Increase: 10ct Tuning - The Slow Way Diesel Engine Technology
No new posts Can the diagnostic tool also be used for the 10-cent tuning? Diesel Engine Technology
No new posts PD Engine Tuning: 10 or 20 Cent Upgrade On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. VAS 5051 Login: Passat AKN Diagnostics Diesel Engine Technology
