Clutch Problems Audi A6 C4 TDI 1.9
MichaelM
Post18-09-2002, 16:41    Subject: Clutch Problems Audi A6 C4 TDI 1.9 Quote
Hello TDI community,
I have the C4 mentioned above, and I have the following question(s).
- Is the clutch operated via the pedal, using a cable or a hydraulic system?
- My problem is the following: Since yesterday, I've only been experiencing the usual resistance in the last third of the pedal travel (when I press the clutch pedal). This happened suddenly, from one day to the next. The clutch isn't slipping. The car has approximately 100,000 km (or about 62,000 miles).
Could it be that the clutch cable is frayed or damaged?
Has anyone else experienced the same problem?
Thank you in advance.
Michael.
Translated on 18-10-2026, 7:32.
Jan6K
Avatar-Jan6K
Post18-09-2002, 18:51    Subject: Clutch Problems Audi A6 C4 TDI 1.9 Quote
AFAIK, all TDI models have hydraulic clutches. Your problem might be due to insufficient hydraulic fluid or air in the system. Check if there's enough brake fluid, as the clutch hydraulics use the same reservoir.
Jan.
1Z5 CFHF / AHB H4D
Translated on 18-10-2026, 7:33.
MichaelM
Post18-09-2002, 19:43    Subject: Clutch Problems Audi A6 C4 TDI 1.9 Quote
Hello Jan,
Danke für den Tip. Der Füllstand im Hydrauligbehälter steht zwischen min und max. Ich denke mal daß das genügen sollte. Oder? Wie kann ich das System entlüften oder entlüftet es sich selbst. Ich war am Montag in der Werkstatt (Audihändler) und die haben mir die Wasserpumpe gewechselt. Aber dafür muß doch das Hytrauliksystem nicht geöffnet werden. Oder?
Thank you.
Michael.lOkay, here's the translation:
Thank you.Regards,
Translated on 18-10-2026, 7:34.
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 4 Clutch Slipping - 81kW Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Problems? Get Expert Help Now! Diesel Engine Technology
No new posts LUK Clutch for ALH engine Diesel Engine Technology
No new posts Coupling Diesel Engine Technology
No new posts A4 8K SAC Clutch: Replacement & Upgrade Transmission, Chassis, Body & Interior
