Remove Mirror Cover: How-to Guide
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Hati
Post12-03-2005, 15:17    Subject: Remove Mirror Cover: How-to Guide Quote
Hi.
How do I remove the mirror cover on a Golf 4? There's something loose inside that rattles when I close the door.
Translated on 29-08-2026, 10:59.
Marco
Post12-03-2005, 15:39    Subject: Remove Mirror Cover: How-to Guide Quote
According to Etzold, the cover itself cannot be removed directly. However, you can remove the internal components of the mirror. There is a small hole in the center, underneath the mirror. Insert a suitable screwdriver into the hole to release the retaining clip. Then, pull the mirror upwards to remove it. We are not liable for any damage caused by broken glass!
EDIT: The lower part of the mirror, which often has an unpainted bracket, remains attached to the car.
Translated on 29-08-2026, 11:00.
Hati
Post12-03-2005, 15:43    Subject: Remove Mirror Cover: How-to Guide Quote
Thank you, Marco.
It probably makes more sense to carefully pry off the mirror glass beforehand using a wide putty knife. Hopefully, the mounting is clipped in place within a round plastic ring, like in the 3er Golf. Can you confirm that?
Translated on 29-08-2026, 11:01.
Marco
Post12-03-2005, 15:50    Subject: Remove Mirror Cover: How-to Guide Quote
Hello Hati,
I can only find information about this topic in the Etzold manual, as I haven't done it myself before. However, according to the instructions, mirror glass is installed as follows: Using a flat plastic spatula, carefully press the mirror glass towards the back, as viewed in the direction of travel, starting from the bottom and then the top.
Hati
Post12-03-2005, 15:56    Subject: Remove Mirror Cover: How-to Guide Quote
Thank you.
Translated on 29-08-2026, 11:02.
No new posts Removing the rocker arm assembly from a 2.0 TDI engine. Diesel Engine Technology
No new posts Golf II - Spurstange vom lenkgetriebe demontieren? Transmission, Chassis, Body & Interior
No new posts Bora Variant Heckklappenverkleidung demontieren Transmission, Chassis, Body & Interior
No new posts Golf III TDI: Remove Underbody Panel Diesel Engine Technology
