Adaptation Channels of Engine Control Unit (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post03-06-2002, 21:06    Subject: Adaptation Channels of Engine Control Unit Quote
To implement this, a diagnostic system is required.
Modifications should only be made on these channels if a certain level of expertise is present. Due to extreme settings, engine damage may occur.
Not all tax equipment allows for these adjustments!
Select engine control unit.
For channels 1, 3, 4, and 5, please log in using the username "12233".
Select adaptation
Select the appropriate channel and change the value (can only be changed within certain limits).
Channel 1: Injection Volume
Channel 2: Idle Speed
Channel 3: Air Mass
Channel 4: Injection Timing
Channel 5: Starting Amount
TschĂŒss
Michael II
Post21-09-2002, 12:30    Subject: Impact of Adaptation Channels Quote
/viewtopic.php?t=1129
Ratings - Adaptation Channels of Engine Control Unit
No new posts Engine Control Unit (ECU) Data Diesel Engine Technology
No new posts Adaptive Channels: Ahu Solutions On-Board Diagnostics (OBD)
No new posts AAT Adaptation Channels: A Guide Diesel Engine Technology
No new posts Adaptation channels for older R5 TDI engines On-Board Diagnostics (OBD)
