[?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub
Stefan Schlünder
Post08-03-2005, 23:41    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
I need advice from the community.
Some of you might be familiar with our racing diesel engine based on the G3 AFN platform. We used the winter to make a few icon_rolleyes.gif modifications to the engine. This allows us to expect a bit more power (diagram will be available when it runs icon_wink.gif), and since the original transmission made extremely strange noises during the last races, we thought, 'Let's just quickly install a 6-speed transmission.' Thought - Done. So far, no unsolvable problem.
However, we overlooked the fact that the power of the engine should also reach the wheels. icon_redface.gif To do this, one needs - as the discerning reader has already guessed - drive shafts...
Apparently, the waves are supposed to fit from a Seat Ibiza with 130-160 horsepower (newest model). Unfortunately, the friendly mechanic is completely overwhelmed and cannot help us. And, for the time being, neither we nor he want to order on suspicion.
Brief description of the problem: 6-speed PD gearbox needs to transfer power to the Passat VR6 wheel hub. The hub should be the same as that of the Golf GTI/VR6, according to our information.
Do any of you have any advice? If more information is needed to answer the question, please let me know. We can also implement robust 'DIY' solutions.
Greetings
Stefan
Post09-03-2005, 1:06    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
At least, I can confirm, based on the fuse rings, that the diameter of all three wheel hub bearings is identical at 72 mm.
And the Ibiza ASZ/BPX waves are, in turn, identical to the ASZ-Polo wave. But is there another way, for example, that fits icon_question.gif
You can, however, at least order all the Brocken models from the local VW dealer for viewing, but Seat doesn't need them.
dieter
Karma: +13 / -0   Thank you, like it!
Post09-03-2005, 8:59    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
However, you can at least order all the Brocken models from the local VW dealer for viewing, Seat doesn't need them.
Not all dealers can do this, but "Hauptändler" (I don't know what the equivalent is for VW) in Hamburg is Raffay, and they can. The others have to buy them, and they naturally won't do that.
Greetings
Dieter
T3 syncro 16 AFN
Marco
Post09-03-2005, 9:07    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
Raffay? I can hardly believe they would do that. Even if they could.
I didn't find the parts sale there very exciting. Which branch, the one in Harburg?
dieter
Post09-03-2005, 11:59    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
I didn't say that they are doing it, but they could. Raffay manages the central warehouse for Northern Germany (in Norderstedt), and the Raffay companies can also receive parts in bulk. That's what someone told me, at least.
However, I had such bad experiences with Raffay (not in Harburg, but on Fruchtallee) that I will not go there anymore.
Dieter
T3 syncro 16 AFN
Stefan Schlünder
Post09-03-2005, 13:26    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
We also noticed the issue with the wheel bearings when we converted our bike frame from the 4-hole hub to the 5-hole hub. After we were finished, we realized that we could also have replaced the entire wheel rim. icon_rolleyes.gif Well, if you have nothing to do, you make yourself busy...
It remains to be clarified whether the Polo ASZ axle with its splines will fit into our hub. Does anyone know the diameter and number of teeth?
We will definitely know then that there is a combination of New Gear to Old Hub. Then we just need to find one that fits the length.
Greetings
Stefan
Post11-03-2005, 11:08    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
Stefan Schlünder wrote:
The only thing left to clarify is whether the Polo ASZ axle, with its splines, will fit into our hub. Does anyone of you know the diameter and number of teeth?
Hi Stefan,
Currently, I can only tell you about the external nut: M16 x 1.5.
I'm going to remove a hub cap and see if I can spot anything else.
EDIT:
No, there's nothing more to see.
On the side of the wheel, the hubs are fixed with a strange 12-sided nut, which already looks like it has been precisely machined from the factory.
Maybe this will help you somehow...
Golfchriss
Post11-03-2005, 15:56    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
Hello Stefan,
I have asked the same question here in this forum weeks ago. Unfortunately, no one has responded yet.
The ERF gearbox problem was the gearbox flange. In the VR6, the 100mm wave discs are installed, but they are too small.
You need to install the flange shafts 02A 409 343 C from the Touran, and you can continue to use the VR6 gearbox shafts.
Now I will proceed with the renovation as described below.
Could you please tell me, in the 'Gewgenzug' (presumably a specific train or vehicle), how you have implemented the gear/transmission and suspension systems? I currently don't have any ideas about what would fit there. icon_confused.gif
Hello
Christoph
Stefan Schlünder
Post12-03-2005, 1:07    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
Great, that also sounds solid! I'm going to build a sentence now.
Could you please tell me, while we're on the train, how you implemented the gear bearings and suspension? I currently don't have any ideas about what would fit there. icon_confused.gif
We have built it. Since it is a race car, the principle 'Form follows function' applies. The solution has not yet been implemented, as the engine is not yet 'inside'. I'll be back at the Nürburgring this weekend and will be taking some photos and posting them here early in the week.
Greetings
Stefan
Stefan Schlünder
Post15-03-2005, 11:06    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
(...) I will take some photos and post them here early in the week.
The digital camera isn't working. icon_confused.gif I would still like to try to explain it.
On the 6-speed gearbox, we have attached a construction made of flat iron, which is supported by the original front axle bearing once. The other 'end' of this construction is supported by the same (not the same) bearing, which we installed in the bracket directly next to the gearbox, on the left side, in the direction of travel. To this end, we cut a hole and reinforced the edge with plates.
This design has not yet been tested for functionality and durability. As this is a car that will only be used in competition, we will not have any issues with TÜV (German technical inspection authority) or other relevant certifications. I would advise against implementing this on a road vehicle, as I cannot assess how the structure will behave in the event of an accident, or what the modified spar indicates in terms of impact.
Greetings
Stefan
sunny
Post16-03-2005, 20:25    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
hello
@stefan
I just looked at the images on your website about the 6-speed transmission, and I'm still not quite clear on how you've implemented the suspension icon_confused.gif.
What type of transmission is it?
I'm currently trying to install a DRW (donor rear wing) on an Ibiza 6K (basically a Golf 3, but a bit narrower icon_evil.gif).
The original recording of the DRW is completely different from that of the CYP (5-speed).
Therefore, I am trying to implement a similar mounting structure to that of the CYP, which was originally... The holder would also fit with the distance between the holes, but for some reason, the holder is then mirrored. icon_twisted.gif
Have you ever considered adapting the 'mounting points' of the 5Gang system to the 6Gang system? icon_arrow.gif This could allow the original mounting points on the chassis to be reused.
As far as I can see from the pictures, you seem to be planning to keep the 6-speed gear lever in its original position and modify the chassis accordingly.
Maybe your camera will work again soon, and you can then take some photos of detailed shots.
Think about it: the TÜV (which I unfortunately need) would prefer a change to the registration documents instead of a change to the bodywork.icon_twisted.gif
Stefan Schlünder
Post17-03-2005, 10:59    Subject: [?] 6-Speed PD Gear Output Shaft -> G3 VR6/GTI Hub Quote
(...)I just took a look at the images on your homepage about the 6-speed transmission, and I'm still not quite clear on how you've implemented the suspension. icon_confused.gif
Oops, I didn't realize we had already taken pictures of it. icon_rolleyes.gif The gearbox is from a 130hp PD Golf (allegedly). I can't tell you the registration number right now, as the gearbox is in Nürburg and I don't have access to it. icon_cry.gif
http://www.mungo-racing.de/gallery/albums/album03/DSCF1894.sized.jpg
The connection between the gearbox and the chassis is then realized through a custom-made construction using flat iron. We also designed the engine mount near the turbocharger in this way. Worked wonderfully in 2004 and we now have more space when changing the turbocharger compared to the original bracket. icon_wink.gif
As it appears from the images, it seems that you are planning to keep the 6-speed gear lever in its original position and to modify the chassis accordingly
Yes, of course! If the transmission fails during the race, it is easier and faster to replace it with another one without having to re-install the mounts.
Greetings
Stefan
P.S.: Once my camera is working again, I'll share some pictures. The engine with the gearbox will be installed in about 2 weeks, then I will take a series of photos.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T5 CAA Drive Shaft spins in the gearbox 7-speed DSG Transmission, Chassis, Body & Interior
No new posts Upgrade 5-speed to 6-speed gearbox VW G3 AHU Diesel Engine Technology
No new posts New driveshaft, but which one fits the Audi A6 AVF with a... Transmission, Chassis, Body & Interior
No new posts Golf 5 1.9 TDI 5-speed 6-speed gearbox ZMS clutch Diesel Engine Technology
