Signal Verbrauchsmessung TDI 1Z | Posts 16+
Go to page: Previous  1, 2
Post05-04-2005, 18:11    Subject: Quote
Maik wrote:
Does anyone here perhaps have a part number for a contact for an engine control unit (ECU) with the following specifications: 1Z, year of manufacture 94, engine code 028906021C.
Sure.
Die Nummer fängt mit 000979 an. Then for...
- 0.35mm² 019
- 0.5 mm² 021
- 1.00 mm² 131
- 1.00mm² 133 (this seems to be a smaller contact size (1.5 instead of 2.8mm))
- 2.50mm² 225
It goes at the back. And if you want, you can add an "A" at the back to indicate it's gold-plated.
Example: 0.35mm² gold-plated: 000 979 019 A
Sure, here's the translation:
"Guste" is a German word that means "gust" or "gust of wind." It can also be used to describe a sudden burst of something, such as laughter or anger.
Translated on 14-10-2026, 7:43.
Maik
Post09-04-2005, 16:01    Subject: Quote
Thank you for the numbers.
I've now also measured the signal. It's not a PWM signal, but simply a rectangular pulse. The pulse sequence then corresponds to the amount of fuel consumed. I'm going to build a counter and measure the number of pulses per 100km, so I can understand how the relationship between pulses and fuel consumption works.
Thank you for all the information.
Maik.
Translated on 14-10-2026, 7:45.
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Signal too slow, signal too fat 3.0 TDI CTBA Diesel Engine Technology
No new posts Missing Data Frame Signal: Troubleshooting Guide Diesel Engine Technology
No new posts A4 2.5 TDI G28 - No Signal Diesel Engine Technology
No new posts NOx Signal Low: Troubleshooting Guide Diesel Engine Technology
