Heckwischer motor with an unusual wiping method
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
donalexo
Post30-03-2005, 12:20    Subject: Heckwischer motor with an unusual wiping method Quote
Hello everyone!
Last week, I replaced the windshield wiper motor on my Golf 4, because the wiper arm was again sticking icon_twisted.gif
After the initial function test, I was quite surprised by the wiping behavior of the motor. In the "wipe-wash" mode, i.e., when a good amount of water is supplied via a pump, the motor behaves as expected. D.h. er moves continuously from one end to the other (180°).
However, I was surprised when I tried the intermittent operation, because now the wiper arm makes 2 pauses of approximately 60° during the first wiping cycle, and only one pause in the middle position during each subsequent intermittent wiping cycle.
Apparently, the wiper motor comes from a 2002 Passat Kombi. Can anyone here on the forum confirm this unusual swiping behavior, or is it actually a defect?
As far as I know, from both the Golf and the A3, I'm only familiar with rear wipers that continuously wipe, meaning they always wipe 180 degrees without stopping.
Thank you for your feedback.
Greetings
Alex
Touran 1.9 TDI, EZ 09/2004
wutz
Karma: +11 / -1   Thank you, like it!
2006 Seat Leon
Post30-03-2005, 12:33    Subject: Heckwischer motor with an unusual wiping method Translating...
[Translating...]
Bei unserem Firmen Passat Kombi Bj. 2004 wird auch ohne Pause von einer Endlage zur anderen gewischt.
Vielleicht paßt die Ansteuerung nicht oder dein Motor hat irgendeinen defekt.
Post30-03-2005, 14:02    Subject: Heckwischer motor with an unusual wiping method Translating...
[Translating...]
Mein 3bg 2002 wischt auch ohne Unterbrechung die 180°. Denke daher auch das ein Defekt möglich ist.
Avatar-Jan6K
Post30-03-2005, 18:04    Subject: Heckwischer motor with an unusual wiping method Translating...
[Translating...]
der 2001er 3BG meiner Eltern wischt auch in einem Stueck durch.
Viele Gruesse,
Jan
1Z5 CFHF / AHB H4D
edgar-s
Post27-04-2005, 11:59    Subject: Heckwischer motor with an unusual wiping method Translating...
[Translating...]hatte ich auch mal, gr. Zahnrad mit den Schleifkontakten reinigen hilft
No new posts Sunroof, wind noise, rear washer motor, dark FIS Transmission, Chassis, Body & Interior
No new posts Golf IV: Heckwischermotor rinnt (Metallröhrchen gebrochen) Transmission, Chassis, Body & Interior
