Climatronic Error Codes: Troubleshooting Guide
doba
Post11-05-2005, 14:28    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
Hello everyone,
Does anyone here have any idea what this error code is trying to tell me?
01274 - Actuator for pressure relief valve (V71).
000 - - - Sporadically
Does that mean the error appeared once and then disappeared?
It would be great to get some suggestions for solutions...
Thank you in advance...
Translated on 14-09-2026, 3:43.
Trecker Treiber
Post11-05-2005, 20:46    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
This means that the actuator motor is occasionally getting stuck. It's an old problem that sometimes occurs with older actuator motors. You'll probably have to replace it sooner or later.
Translated on 14-09-2026, 3:44.
doba
Post12-05-2005, 13:00    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
That's a really helpful tip.
I also occasionally experience the problem where the ventilation in "AUTO" mode of the Climatronic briefly stops and then immediately restarts... Could this be related to the error mentioned above?
The vehicle in question is a Seat Ibiza, 1.9 TDI, 130 horsepower, manufactured in 2004.
Translated on 14-09-2026, 3:45.
Post12-05-2005, 14:02    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
I also occasionally have the problem that the ventilation in AUTO mode of the Climatronic turns off briefly and then turns on again immediately...
Could this possibly be related to the error mentioned above? }
"My A3 also makes a noise for a few minutes after starting, especially when the cooling system is working hard. But everything seems to be functioning normally."
doba
Post12-05-2005, 14:16    Subject: Climatronic Error Codes: Troubleshooting Guide Quote
That could also be the case...
I've also noticed that the time intervals get longer the longer I drive when the Climatronic is behaving like that...
I only noticed that recently...
Strange, strange...
But thank you for the tip.
Translated on 14-09-2026, 3:46.
No new posts Error code Climatronic 3B, model year 1999, 2000 model Troubleshooting & Guides
No new posts Climatronic Error: Doku Sharan 7M8 Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reading Faults - VW Climatronic from Hella Troubleshooting & Guides
No new posts Climatronic Error Code 313: Troubleshooting Guide Diesel Engine Technology
No new posts Climatronic Error Code 04F7: Diagnosis & Troubleshooting On-Board Diagnostics (OBD)
No new posts Climatronic G3 TDI Transmission, Chassis, Body & Interior
No new posts T4 Climatronic: Climate Control System Transmission, Chassis, Body & Interior
