Audi A4, 66/81 kW TDI, pulley for generator, freewheel.
Affected vehicle identification numbers:
WAU ZZZ 8D Z SA 000 335 to WAU ZZZ 8D Z SA 151 550.
WAU ZZZ 8D Z TA 000 134 to WAU ZZZ 8D Z TA 330 651.
WAU ZZZ 8D Z VA 000 113 to WAU ZZZ 8D Z VA 294 233.
WAU ZZZ 8D Z WA 000 138 to WAU ZZZ 8D Z WA 237 097.
Cause:
In certain Audi A4 vehicles equipped with a 66 kW or 81 kW TDI engine and an automatic transmission, there is a possibility that irregularities in the belt drive system may lead to the failure of the belt tensioner.
Procedure:
The rigid pulley on the generator should be replaced with a pulley that has a freewheel mechanism.
At the same time, the belt tensioner and the ribbed belt need to be replaced.
Important:
Active customer outreach is not performed.
Parts per vehicle (depending on the generator model).
Conversion kit for BOSCH generator, 1 x parts set 028 998 998 A, or...
Conversion kit for VALEO alternator, 1 x parts kit 028 998 998 B. Tschüss
Michael II
Translated on 12-10-2026, 10:33.
