Replace G3 ABS sensor
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Post30-06-2005, 8:47    Subject: Replace G3 ABS sensor Quote
After a friend with a faulty ABS sensor on his Ibiza visited me, it seems like the problem has now affected my Golf -> the ABS warning light is on.
How quickly and easily can the sensor be replaced?
Subject: ABS request for A61 track day this weekend.
I'm planning to go to the A61 track this weekend and would like to request ABS (which is always useful there!). However, I only have a short window of time available on Saturday afternoon, if at all.
Can you complete the swap in 30 minutes (without a lift, using a jack)?
Thank you.
Translated on 07-07-2026, 19:58.
ObenbeiMutti
Post30-06-2005, 11:48    Subject: Replace G3 ABS sensor Quote
Hello.
I think the wheel bearings need to be removed, but that's just a guess.
extremely vague memory...
...so, really, with absolutely no guarantee.
Translated on 07-07-2026, 20:02.
Post30-06-2005, 14:54    Subject: Replace G3 ABS sensor Quote
Wheel bearing gone?
I can't imagine that. The wheel bearings would have to come out completely to replace the rotor.
I want to replace the sensor that is screwed into the RL housing.
Translated on 07-07-2026, 20:09.
golfschrauber1981
Post30-06-2005, 19:08    Subject: Replace G3 ABS sensor Quote
If the sensors are not stuck in the wheel bearing housing, it shouldn't be a problem.
- Jack up.
- Flat tire.
- Disconnect the plug.
- Loosen the screw (I think it's an M5 Allen key).
- Remove the old sensor from the wheel bearing housing.
-new, everything's back on, ready to go.
Translated on 07-07-2026, 20:14.
Arno
Post30-06-2005, 20:48    Subject: Replace G3 ABS sensor Quote
Let's assume that you have a sensor on the rear axle that is failing. Replacing it isn't quite as difficult as it is on the front axle icon_evil.gif.
Remove the old sensor from the wheel bearing housing .
'Forcing it out somehow' would probably be a more accurate description.
I had to really force mine out because they were stuck in the bore. Afterwards, I used a Dremel or something similar to grind away the rust from the bore, and possibly used a magnet to 'suck up' any metal shavings near the toothed ring. Then, I installed the new one. Without grinding, the new one would be very difficult to insert and remove, and I was afraid of damaging the new sensor during installation, so I preferred to grind everything away.
But, in my opinion, half an hour is not enough.
Translated on 07-07-2026, 20:20.
No new posts P246E - Exhaust Gas Temperature Sensor (EGS) Bank 1 Sensor 4 General Tips
No new posts Intake Air Temp Sensor P0110: Causes & Fixes General Tips
No new posts P0341 - Camshaft Position Sensor (G40): Implausible Signal Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LDA Sensor: Types, Function & Applications Diesel Engine Technology
No new posts MAP Sensor for AKN Engine On-Board Diagnostics (OBD)
No new posts What kind of sensor is this? Diesel Engine Technology
No new posts Oil temperature sensor Diesel Engine Technology
