SB beim 1z oder Was mache ich falsch? | Posts 16+
Go to page: Previous  1, 2
wurbel
Post23-06-2005, 5:20    Subject: Quote
@ lappen: Sounds good!
The first workshop probably installed the timing belt incorrectly. Due to extreme twisting of the pump, it started up more or less improperly.
'The second mechanic installed the spark plug with the two electrodes and re-gapped it – the pump needs to be realigned afterwards. It still doesn't start well, but it runs better than it did on the W1.'
If it starts today, I'll have to go to the hardware store anyway, so I can also check the logs for Ulf – let's see.
Translated on 07-08-2026, 17:04.
wurbel
Post01-07-2005, 15:01    Subject: Log files analysis and management Quote
I once took logs with different measurement blocks, but I can't find my documentation for them anymore.
Just for fun:
http://www.big-game.de/db101.html
However, I've experienced some more problems after driving about 300 kilometers yesterday.
But first, take a look at the logs...
Translated on 07-08-2026, 17:05.
nobbif
Post01-07-2005, 19:07    Subject: Quote
Hello wurbel,
We've also encountered the problem of an incorrectly timed injection start before. I used to measure the pump timing using a clock (and I still think it's a good method).
If you need the settings for the 1Z, here they are:
Stroke of the lifting piston at top dead center: 0.70 mm +/- 0.02 mm.
The tolerance range is from 0.65 mm to 0.75 mm.
Regards, nobbif.
Passat 1Z with 420,000 km, Passat 35i AFN with 200,000 km.
Translated on 07-08-2026, 17:06.
Roadagain
Post09-07-2005, 21:57    Subject: Quote
Okay, I would first make sure the engine is properly warmed up.
Then, start the timing checker.
Check the box if the temperature is above 80°C = OK.
Then I suspect the following will appear: 'SB not visible outside the display area (late).'
Then, rotate the pump towards the early position until the sensor is properly aligned.
Greetings.
Translated on 07-08-2026, 17:08.
No new posts Documentary: Octavia 1 / Golf IV fuel gauge malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Engine Software: Label File Error? On-Board Diagnostics (OBD)
No new posts 2.0 TDI (BMN) Are your PD elements clogged or misconfigured? Diesel Engine Technology
No new posts Retrofitting ESD/ASR for Audi A4 Diesel Engine Technology
No new posts E-Gas Sensors: Resistors vs. Inductors On-Board Diagnostics (OBD)
