Syringe Pumps: Precise Fluid Delivery Systems
ross
Post13-07-2005, 11:05    Subject: Syringe Pumps: Precise Fluid Delivery Systems Quote
hello,
'On my 1994 Passat (1Z), the warning light for engine electronics occasionally illuminates.'
It's only the engine power that's noticeable; the engine runs smoothly without any jerking or hesitation.
I received the following message from wagcom:
00542 - Needle feed mechanism.
05-10 - Entrance open - Intermittent.
I checked the needle lift sensor according to the procedure, but there's no change (no misfiring).
Now I'm going to clean the cable connections and add fuel injector cleaner.
Can anyone give me some advice here?
Translated on 12-08-2026, 0:04.
Post13-07-2005, 11:20    Subject: Syringe Pumps: Precise Fluid Delivery Systems Quote
05-10 - Input open - Intermittent
= Connection interrupted.
So, it could be a loose connection in one of the connectors leading to the control unit, a broken wire, or a problem with the sensor's coil itself.
Translated on 12-08-2026, 0:06.
Martin R
Post13-07-2005, 19:59    Subject: Syringe Pumps: Precise Fluid Delivery Systems Quote
Have you ever measured the resistance of the NBF?
Translated on 12-08-2026, 0:07.
ross
Post14-07-2005, 14:09    Subject: Needle insertion device Quote
What is 'NBF'? Is it the needle lift mechanism?
I haven't measured anything yet. What should the resistance be in ohms?
I've cleaned the contacts and checked the wiring harness; everything looks okay.
Today I went to Volkswagen. The replacement costs €220. If the sensor is actually faulty, a new one needs to be installed, but if not, it's just frustrating.
Are these parts available anywhere cheaper?
Translated on 12-08-2026, 0:08.
Martin R
Post14-07-2005, 14:25    Subject: Needle lifter - Spare parts & accessories Quote
What is 'NBF'? - Is it the needle lift mechanism?
With NBF (Needle Movement Sensor), the term refers to the needle stroke generator.
In the truck sector (specifically for MAN vehicles), the target value is between 80 and 120 Ohms.
As far as I know, this threshold value also applies in the passenger car sector.
However, as I said, I'm not entirely sure anymore.
Translated on 12-08-2026, 0:09.
ross
Post14-07-2005, 17:27    Subject: NHG: What is it? Definition & Explanation Quote
I found it online; it's supposed to be around 100 ohms.
Tomorrow I will take measurements, but there seems to be a loose connection...
'Furthermore, the indicator light doesn't stay on constantly, and besides the power issue, you don't notice anything else.'
And if I restart, the problem goes away.
Translated on 12-08-2026, 0:11.
ross
Post15-07-2005, 19:51    Subject: NHG: What is it? Definition & Explanation Quote
Today I installed a used part, and everything is working perfectly.
Translated on 12-08-2026, 0:12.
Post15-07-2005, 20:01    Subject: Syringe Pumps: Precise Fluid Delivery Systems Quote
Great, with a little luck, that's it icon_smile.gif.
Martin R
Post20-07-2005, 19:08    Subject: NHG: Your Guide to German Mortgage Insurance Quote
today I installed a used part, and everything is working perfectly.
Just out of curiosity:
Have you ever measured the resistance of the old NBF?
Translated on 12-08-2026, 0:13.
ross
Post21-07-2005, 21:53    Subject: NHG: What is it? Definition & Explanation Quote
Yes; 107 ohms.
the 'new' 98 Ohm
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Feed Open: Valve/Sensor Status Diesel Engine Technology
No new posts What kind of donor is this? Diesel Engine Technology
No new posts MAP sensor G71 Diesel Engine Technology
No new posts G28 Encoder Position: Find & Troubleshoot Diesel Engine Technology
