steuergerät resetten..geht das mit batterie abklemmen?? | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
goettmann
Post02-08-2005, 8:10    Subject: Quote
Is it a TDI manufactured in 2005 (EU3)?
What kind of vehicle is it?
I haven't encountered a single VAG TDI with permanent power at the MSG (Modular Solid-State Generator) yet.
BJ05? How is that possible? Since January 1st, 2005, only vehicles compliant with the EOBD2 standard have been allowed to be sold.
In EOBD2 vehicles , an emission-related fault like the one you had cannot be cleared.
If the error were to be deleted, it would constitute a violation of the EU emissions regulations and represent a step backward towards all older vehicles.
EDIT:
There are also other contributions on this topic...
/viewtopic.php?t=5762 (latest thread by Gremlin)
Do not reset by disconnecting the battery!
Translated on 21-07-2026, 22:00.
AndyHIP
Post02-08-2005, 10:52    Subject: Quote
Is it a Seat Leon TDI (ARL)?
Translated on 21-07-2026, 22:01.
m.w.
Post02-08-2005, 11:33    Subject: it does something, though... Quote
I once had my van (T3, 1Z) break down at a highway gas station. It wouldn't start again (immobilizer issue), so I checked everything. Then I spoke to an ADAC [German roadside assistance] employee. He initially didn't believe me when I told him there was a large Golf 3 in front of him, and he mumbled something about just disconnecting the immobilizer.
He quickly realized that it was actually a Golf 3 in disguise. He thought for a moment and then asked, "What do you do when Windows freezes?" I replied, "I close all the windows and restart."
He then disconnected the battery and said, "Wait at least the length of a cigarette," but he reconnected it after 3 minutes, and everything seemed to be working as if nothing had happened!
I had already tried everything possible beforehand (plugging and unplugging things, turning the key, etc.), but nothing worked.
So, something is definitely being deleted there...
Hi Marcus,
Okay: Control number: 281 001 316/317 or 028 906 021 G (formerly AP, handwritten alteration).
Translated on 21-07-2026, 22:03.
goettmann
Post02-08-2005, 13:57    Subject: Re: It does something, but... Quote
The car wouldn't start again (immobilizer issue).
So, something will definitely be deleted there.
The WFS is de-energized, but not the MSG. In the '1z' mode, the famous 109 relay completely cuts off power to it.
Translated on 21-07-2026, 22:05.
Rudi
Post04-08-2005, 6:58    Subject: Quote
Well... save and save...
While capacitors in an EDC also store something (energy), they do so not for the purpose of...
to obtain any data (they are too small for that; also, they are too unreliable).
Non-volatile data storage is typically achieved using (mostly serial) EEPROMs.
If the Electronic Control Unit (ECU) deactivates relay 109, it is disconnected from the battery.
@goettmann:
I admire your patience icon_cool.gif.
Rudi
Translated on 21-07-2026, 22:06.
golfschrauber1981
Post05-08-2005, 18:25    Subject: Quote
Der Sinn !!
Im STeuergrät befinden sich kondensatoren die den Strom halten zum Speichern !!
Brücke die Kalbel eine Nacht und dein Steuergerät ist RESETET !!
As mentioned several times here, disconnecting the Ralais 109 does not help to isolate the circuit from the MSG, so short-circuiting the battery terminals absolutely DOES NOT HELP! icon_evil.gif
Translated on 21-07-2026, 22:07.
Julian
Post05-08-2005, 20:03    Subject: Quote
Since Göttmann (<- Hats off to your patience!) and Rudi have already mentioned everything worth knowing, and the rest can be found through a search function or Google: Done! icon_smile.gificon_wink.gif
Translated on 21-07-2026, 22:08.
No new posts VW Passat: ESP Light On - What to Do? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Disconnect the battery Electrical Systems, Vehicle Electronics, Multimedia
No new posts TDI 110HP: Disconnect & Reconnect Tuning Box On-Board Diagnostics (OBD)
No new posts AGR Disconnect: Engine Coolant Temp. Error 00522 Diesel Engine Technology
No new posts control unit settings On-Board Diagnostics (OBD)
