Subject: EGR deactivated / Turbocharger whistling audibly at idle | Posts 16+
Go to page: Previous  1, 2
Forenheini
Post08-08-2005, 14:10    Subject: Subject: EGR deactivated / Turbocharger whistling audibly at idle Quote
I temporarily disabled the EGR system for testing purposes.
I immediately noticed the whistling sound of the turbocharger when the engine was idling!
What do you think about this??? I'm not entirely sure (others here probably know better than I do...), but is the EGR valve actually open at idle?
Translated on 18-07-2026, 13:47.
Achim
Post10-08-2005, 17:50    Subject: Subject: EGR deactivated / Turbocharger whistling audibly at idle Quote
Yes, in the case of the ASV, the EGR valve is open at idle and closes after approximately 2 minutes.
I observed the same thing as 'Brösel.'
Translated on 18-07-2026, 13:48.
poppel
Karma: +1 / -2   Thank you, like it!
Post10-08-2005, 22:08    Subject: AGR back on, and less (turbo) noise Quote
Nachdem ich gestern den Turbo erneuert habe und die ARG tot gelegt habe, höre ich den Turbo deutlich beim anfahren ab ca. 1100 U/min. Beim schalten ca. 2000 U/min ( Motor kalt) ändert sich der Sound syncron zur Drehzahl. Nach lesen des Beitrags habe ich dann heute die AGR mal Probehalber wieder in betrieb genommen und jetzt ist der Turbo bei weitem nicht mehr so deutlich zu hören. Weiterhin kommt es mir so vor als wenn der Motor jetzt mit AGR etwas weniger Leistung hat. Is that correct?
So, should I remove or replace the EGR valve? Will it damage the engine to drive without an EGR valve?
I would prefer to drive without the EGR system, especially after seeing how much soot buildup had reduced the cross-sectional area of my intake manifold.
After I identified the catalytic converter as the cause of the performance loss, I now have a new one. Does driving without the EGR valve affect the catalytic converter?
T4, year 1998, 2.5 TDI ACV engine, chip tuning, 298,000 km mileage, no oil consumption, turbo, catalytic converter, and exhaust system are new.
Translated on 18-07-2026, 13:49.
Forenheini
Post16-08-2005, 22:11    Subject: Subject: EGR deactivated / Turbocharger whistling audibly at idle Quote
Here is a very informative article about the function of the AGR (Abgasrückführung) and how to disable it; please take a look. I think this should answer your questions; if not, you can ask again. icon_wink.gif
Translated on 18-07-2026, 13:50.
poppel
Post16-08-2005, 23:14    Subject: Technical article Quote
I don't think so, please provide a link.
Thank you!
Translated on 18-07-2026, 13:51.
Forenheini
Post17-08-2005, 7:36    Subject: Subject: EGR deactivated / Turbocharger whistling audibly at idle Quote
Try it here: Click me!
No new posts Turbocharger Repair 1.9 TDI ASZ Troubleshooting & Guides
No new posts Document: Idle running issue, V8 TDI 3.3L AKF engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Whistle: Documentary Analysis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Is the wastegate opening audible? Diesel Engine Technology
No new posts AGR System Decommissioning: Experiences? Diesel Engine Technology
No new posts LMM and AGR Off: What Happens? (Under 3000 Miles) Diesel Engine Technology
No new posts AGR Deactivated: Behavior Unchanged? Diesel Engine Technology
