Wartungzustand mancher Fahrzeuge | Posts 16+
Go to page: Previous  1, 2
ObenbeiMutti
Post29-06-2005, 10:01    Subject: Quote
Okay, okay...
I just spontaneously decided to increase my oil change interval to 120,000 kilometers (or miles).
Translated on 21-08-2026, 3:46.
wolfi_b
Post29-06-2005, 10:32    Subject: Quote
Mephisto wrote:
But another question: How the heck did this happen? And: Actually, the belt should run in the middle, even if it's only as wide as a shoelace!
Well, the pulleys have a larger diameter in the center than at the edge. A narrow belt will move towards the smaller diameter.
I don't understand why the pulleys aren't thinner in the middle.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 21-08-2026, 3:47.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post29-06-2005, 11:25    Subject: Quote
"Hi,"
@Wolfi_b: Exactly because the pulley in the middle has a slightly larger diameter, the belt should run in the middle. The belt only sees the gradient, not the absolute diameter icon_confused.gif.
Based on what I see in the picture, the belt appears to have split lengthwise because a portion of it wasn't running on the pulley but was instead beside it. I strongly suspect that something is wrong with the pulley itself. Perhaps VAG-Tuning can shed some light on this.
"Micha"
Translated on 21-08-2026, 3:48.
joegolf
Post12-09-2005, 8:02    Subject: Quote
I can't help myself: icon_eek.gif
http://www.michaelneuhaus.de/forum/viewtopic.php?t=875
Golf 7 GTI
Translated on 21-08-2026, 3:49.
ng2000
Post12-09-2005, 13:29    Subject: Quote
Regarding brake pads... it's also possible to get by with less! I once had a similar experience with an Audi 80, type 89... it was metal on metal (the rotors were already due for replacement), and you wouldn't believe the braking power you can achieve with just a little more pressure on the brake pedal (and how beautifully red they glow in the night after a long drive icon_smile.gif).
Best regards, Martin.
Translated on 21-08-2026, 3:50.
No new posts VAG Vehicles 2002: Coolant Leak Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vehicles with engine 1Z? Diesel Engine Technology
No new posts LED Interior Lights for DHL Vehicles Diesel Engine Technology
No new posts OBD II Interface: PWM, VPW, ISO 9141-2 Support Diesel Engine Technology
No new posts AGM battery for older vehicles? Electrical Systems, Vehicle Electronics, Multimedia
