1Z doesn't want to anymore!?
chaerte
Post10-10-2005, 11:29    Subject: 1Z doesn't want to anymore!? Quote
The 1Z engine comes from an Audi 80 (91 model year) and was installed in a Transporter T2 approximately 1 year ago. It was running smoothly until a few weeks ago. The rev counter was never installed.
Problem: The engine will not start. The error memory is empty (except for the missing signal from the rpm sensor). When starting, no diesel is coming out of the fuel lines.
Subsequently, the pump was taken to Bosch for inspection and repair, and partially overhauled. No change. Afterwards, the control unit was replaced (it is functioning correctly in another vehicle). Subsequently, the needle position sensor (due to the need for a different reference signal) was also replaced, and all wires from the sensors and actuators of the engine to the control unit were checked. Everything is fine here.
I'm starting to feel like I'm at the end of my rope. What else could it be?
lappen
dieselschrauber likes this.
Post10-10-2005, 12:26    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Die Steuerzeiten passen?
chaerte
Post10-10-2005, 12:50    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Ja, die sind in Ordnung. Vor dem Ausbau der Pumpe und auch nach dem Einbau alles neu eingestellt!
lappen
Post10-10-2005, 12:55    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Wer und was hat man an der Pumpe gemacht? Luft im Kraftstoffsystem?
chaerte
Post10-10-2005, 14:21    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Die Pumpe wurde angegossen und zieht beim Starten auch Kraftstoff. Kommt halt 'nur' nichts aus den Einspritzleitungen. Filter ist neu. Was genau mit der Pumpe gemacht wurde kann ich nicht sagen. Sie war beim Bosch Dienst.
mserge
Post10-10-2005, 16:31    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]
Hast du schon versucht ihn am Hang anlaufen zu lassen? Vielleicht dreht der Anlasser nicht schnell genug.
Kommt Diesel in die ESP?
Kompression O.K.?
Richtiges Diesel getankt, kein Fusel?
Nicht aufgeben...
Serge
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
chaerte
Post10-10-2005, 16:50    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Anlasser dreht schnell genug. Anschleppen brachte auch keinen Erfog (kein Kraftstoff an den Einspritzdüsen).
Kompression sollte o.k. sein. Der Kopf wurde gerade erneuert (Ventile eingeschliffen...). Keine Abnutzungserscheinungen an den Zylinderlaufbahnen. Kompression messe ich trotzdem noch mal. Hat aber sicher keinen Einfluß auf den fehlenden Kraftstoff an den Düsen. Diesel ist von der Tanke nebenan.
Georg-TDI
Post10-10-2005, 17:15    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Kommt denn beim Abstellventil an der ESP überhabt Strom an?
Nicht dass da irgendwelche Kontaktprobleme im Stecker versteckt sind.
Dadurch kannst du auch feststellen ob das STG den Motorstart überhaupt freigibt.
chaerte
Post11-10-2005, 9:43    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]Am Abschaltventil liegen 12V an.
Ein Beobachtung die ich noch gemacht habe ist: Schalte ich die Zündung ein klickt es in der Pumpe 2 mal im Abstand von ca. 1s. So als wenn das Mengenstellwerk 2x gegen einen Anschlag fährt. Das machen andere 1Z nicht.
Post11-10-2005, 13:34    Subject: 1Z doesn't want to anymore!? Translating...
[Translating...]
Dann bliebe noch die Frage, ob es öffnet.
icon_arrow.gif Test 1: Kabel abziehen und mit einer Testleitung von B+ an den Absteller tippen.
Wenn das Ventil öffnet, sollte es leise klicken.
Wenn nicht:
icon_arrow.gif Test 2: Durchgang bzw. Widerstand messen (geschätzte Soll-Größenordnung: nicht über 10 Ohm bzw. in Selbstschrauberbüchern nachsehen / habe gerade keins zur Hand).
Wenn Widerstand OK:
Aufschrauben, Absperrstück probeweise rausnehmen und probieren ob er anspringt.
Wenn ja: Grate Suchen, die die Bewegung blockieren und die Grate entfernen.
Natürlich ohne daß Späne in der Pumpe verschwinden . . .
Das hängt AFAIK von der MSG-Software ab. Erst wenn es mit dem gleichen MSG plötzlich nicht mehr klickt (bei gleicher Motortemperatur), dürfte was faul sein.
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L bis KW 04/2002, Radio schaltet nicht mehr ein Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts V6 TDI AKN springt nicht mehr an Diesel Engine Technology
No new posts Audi A6: Engine Won't Start - Troubleshooting Guide Diesel Engine Technology
No new posts ...springt nicht mehr an On-Board Diagnostics (OBD)
No new posts 1Z springt nicht mehr an Diesel Engine Technology
