Turn off headlights?
poppel
Karma: +1 / -2   Thank you, like it!
Post19-10-2005, 15:32    Subject: Turn off headlights? Quote
Hello, I have a Golf IV that was imported from the EU. When the ignition is turned on, the high beam headlights also turn on. How can I fix this? Can this be resolved with software, or do I need to replace something?
Poppel.
Translated on 25-09-2026, 3:32.
bloesch
Post19-10-2005, 20:50    Subject: Turn off headlights? Quote
hi
It really depends on how the car was "modified" and where it comes from.
Within the Volkswagen Group, some cars allow you to code "Scandinavian countries" (which refers to the daytime running light function) into the control unit. Other vehicles simply have a connection made at the light switch to achieve the same function.
To check this, you could try removing the light switch. If it has been tampered with, you should be able to see it.
Here's how to remove a light switch:
Push the light switch in, turn it in the direction of the parking light, and then pull it completely out.
You might then see something on the wiring harness... like if anything has been tampered with or modified.
However, if the car comes from the Nordic countries, it's more likely that something was installed from the factory.
Translated on 25-09-2026, 3:34.
poppel
Post19-10-2005, 23:45    Subject: Lights: Types, Benefits & How to Choose Quote
The car is from Sweden.
I'll probably check the switch tomorrow, but I think it was probably installed with a WOB unit from the factory.
You're welcome, Poppel.
Translated on 25-09-2026, 3:35.
Post21-10-2005, 8:17    Subject: Turn off headlights? Quote
Is there not a TFL (daytime running light) connector there?
Perhaps searching here or on Google might help...
Translated on 25-09-2026, 3:36.
No new posts Disable ESP: How to Turn Off Electronic Stability Program Diesel Engine Technology
No new posts Turn off auxiliary heater On-Board Diagnostics (OBD)
No new posts Turn AGR on or off via switch Diesel Engine Technology
No new posts Disable the Tempan display plate-off function in the KI? On-Board Diagnostics (OBD)
