LongLife ja oder nein? | Posts 16+
Go to page: Previous  1, 2
Post23-06-2005, 10:44    Subject: Quote
Mephisto wrote:
Which oil, meeting the 505 01 specification, are you considering?
LM Diesel HighTech - but not in the appearance, but already in the canister icon_wink.gif.
The Gratis Dose 506.01 is from Mobil.
That means you only refilled 0.25 liters after ~14,000 kilometers
Yes, the oil level is now lower than it was when the car had 0 km on the odometer. However, I probably won't reach the minimum mark before the next oil change.
The actual consumption is likely to be around 0.5 to 0.75 liters higher now.
Translated on 29-09-2026, 17:09.
Julian
Post23-06-2005, 12:53    Subject: Quote
Until the change, I probably won't reach the minimum amount.
At what mileage is the change due?
Translated on 29-09-2026, 17:10.
Post23-06-2005, 19:06    Subject: Quote
Julian wrote:
At what mileage does the replacement need to be done?
According to the remaining mileage display (read with VAGCOM), it's 87 days, if I recall correctly. By then, it will have accumulated 16,000 km.
The remaining kilometers would probably last longer than my usual daily commute (since there were still quite a few free kilometers available).
I don't really understand the calculation, but ultimately, it doesn't matter to me.
Translated on 29-09-2026, 17:11.
mserge
Post26-10-2005, 13:20    Subject: Quote
@JulianViewing profile: Julian:
You wrote that you would perform long-life servicing as long as there was a warranty on the car. That's basically okay, but what's the point of giving an old engine, which has already been pushed to its limits with long-life servicing, better maintenance when it has already suffered so much? The long-life servicing was only done so that customers could brag to their colleagues that they only need to go to the dealership every 35,000 or even 50,000 kilometers, and that the car is finished at 150,000 kilometers. Then the calculations of the VAG engineers backfired, costing the customers dearly.
I witnessed this firsthand on my own car, at 130,000 km, where all four camshafts had worn down (more than 0.5mm). The workshop was grateful for the €2,886 that the repair cost. To prevent this, you can change the oil every 15,000 km using the best oil available.
If I ever become financially able to buy a new car again, regardless of the brand, you can be sure that the oil will be changed no later than 1 year or 20,000 km, regardless of the manufacturer's recommended maintenance intervals.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 29-09-2026, 17:12.
TDI-NAXTEX
Post26-10-2005, 14:24    Subject: Quote
Opinions on oil change intervals vary widely.
We all know that engines need oil for lubrication and cooling. According to oil manufacturers, today's oils are all capable of reliably providing lubrication and cooling for well over 50,000 km. This is probably one reason why automotive manufacturers have confidently introduced long-life oil change intervals for their models. However, it's not the degradation of the oil that forces us to change it, but rather the limited capacity of the filter elements. Once the filter is clogged and dirty, it can potentially lead to increased wear on engine components due to contaminated oil.
The oils are, in any case, still capable of providing 100% lubrication and cooling even after a complete extended drain interval.
I'm certainly not a proponent of extended oil change intervals. Therefore, I would suggest that if you want to use extended oil change intervals, you should change the oil filter halfway through the interval. The cost is less than 20 euros, and it certainly can't hurt, right?
Passat 3C Variant mit 2,0 TDI
Translated on 29-09-2026, 17:15.
Julian
Post27-10-2005, 7:19    Subject: Quote
@Julian:
You wrote that you would perform long-life servicing as long as there's a warranty on the car. That's basically okay, but what's the point of giving an old engine, which has already been pushed to its limits with long-life servicing, better maintenance when it's already suffered so much? The long-life servicing was only done so that customers could brag to their colleagues that they only need to go to the dealership every 35,000 or even 50,000 kilometers, but at 150,000 kilometers, the car is finished. Then the calculations of the VAG engineers backfired, costing the customers dearly.
Here: https://community.dieselschrauber.org/en/viewtopic.php?t=9786
...we discovered that an LL² oil has a certain shear stability limit, which can lead to increased wear in the engine. This issue has now been resolved with the introduction of LL³ oils, which I have recently started using myself.
I'm still waiting for the wearcheck analysis from my second oil change, but the initial test already showed that LL2 oils have an extremely high capacity for carrying contaminants, and even after 32,000 km, they exhibit an overall better quality compared to, for example, a 5W-40 oil approximately 3,000 km after the last change.
The only thing I've found in the oil is silicon (dust, etc.), and I've tried to reduce it by changing the engine air filter more frequently (every 15,000 km instead of 90,000 km). Let's see if it makes a difference.
I witnessed this firsthand on my car, at 130,000 km, where all four camshafts had worn down (more than 0.5mm). The workshop was grateful for the €2,886 that the repair cost. To prevent this, you can change the oil every 15,000 km using the best oil available.
If I were to become weak again and be able to afford a new car, regardless of the brand, you can be sure that the oil will be changed no later than 1 year and 20,000 km, regardless of the long-life oil interval.
Okay, what kind of AFB are you using? The wear marks you see on the 2.5 are nothing special, almost like a feature or a bug, depending on how you look at it. My own NW looks perfectly fine, as far as I can tell. But it's a 1.9 PD.
My A4, which I use for comparison here in Wü, has already accumulated 240,000 km as a taxi. The tires need to be replaced approximately every 20,000-25,000 km, and the driver is satisfied.
Translated on 29-09-2026, 17:19.
Julian
Post27-10-2005, 7:21    Subject: Quote
I'm certainly not a proponent of long-life oil change intervals. Therefore, I would suggest that if you want to use long-life intervals, you should change the oil filter halfway through. The cost is less than 20 euros, and it certainly can't hurt, right?
Does changing the filter actually make a difference? Do you have any solid evidence (like an oil analysis, etc.) to support that, or are you just doing it based on a feeling?
Translated on 29-09-2026, 17:22.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts Tuning comparison: Chip vs. Powerbox Technical Articles
No new posts VW Service: Worth it or not? Diesel Engine Technology
No new posts PSI PB2000 Tuning Box: Worth it? Diesel Engine Technology
This topic is locked, you cannot edit or reply. Replacing injector(s) on a Volvo V70 D5 185? Yes or no? Diesel Engine Technology
No new posts Longlife Service: Your Questions Answered On-Board Diagnostics (OBD)
