Danilo100 Blaumann
Joined: 03/18/2004 Posts: 12 Karma: +7 / -0 Location: Dorsten
10-04-2005, 0:21 Subject: Airbag Error: Causes and Solutions |
Hello everyone,
I've had the following error in the memory for a week now, and it won't go away.
STG Part Number: 1C0 909 606A
BdV: 27 Airbag vw51 01 02
"One error found:"
000588 - Airbag inflator (driver side) (N95)
32-00: Resistance value too high.
I suspect that the coil spring or the slip ring is defective. Has anyone had experience with this type of failure, or does anyone know the exact error code?
Danilo100 Golf 1J/5, Bj99 MKB: ALH , GKB: EBJ , GRA, Box
VW Passt 3BG Variant AVF, 6 Gang, GRA
Skoda Octavia Combi 2.0 TDI BKM DSG 170PS
Translated on 16-09-2026, 11:57.
Profile PM Email |
Theresias Guest
10-04-2005, 15:20 Subject: Airbag Error: Causes and Solutions |
Please.
00588 - Zünder für Airbag Fahrerseite ( N95): Widerstandswert zu groß
<Defekte> Leitungen und Steckverbindungen nach Stromlaufplan prüfen
<R> Rückstellring mit Schleifring ersetzen
<Z> Airbageinheit Fahrerseite ersetzen
<Steuerger> Steuergerät ersetzen
Translated on 16-09-2026, 11:58.
Danilo100 Blaumann
10-04-2005, 16:43 Subject: Airbag Error: Causes and Solutions |
Thank you very much.
I'll look into the matter more closely in the coming days.
Profile PM Email |
Danilo100 Blaumann
24-05-2005, 21:22 Subject: Airbag Error: Causes and Solutions |
Hello everyone,
I just wanted to give a quick feedback. So, in my case, it was the tension spring. After the installation, I only had to retrain the ESP, and that was it. Now everything is working again.
Danilo. Golf 1J/5, Bj99 MKB: ALH , GKB: EBJ , GRA, Box
Translated on 16-09-2026, 11:59.
Profile PM Email |
miguelito
24-10-2005, 7:44 Subject: Spring Retainer: Buy, Sell, Trade |
Hello everyone, hello Danilo,
I also strongly suspect that the clockspring is broken: there's a sudden clicking sound when steering, and the airbag warning light comes on.
Is this part available separately as a replacement part? Did you replace it yourself? Is there anything special to consider when doing so (besides the usual precautions like disconnecting the airbag battery)?
Thank you.
Michael.
Translated on 16-09-2026, 12:01.
Dieselmattes
27-10-2005, 20:55 Subject: Airbag Error: Causes and Solutions |
If the vehicle has ESP (Electronic Stability Program), then a basic alignment of the steering angle must be performed afterwards.
If the sensors are faulty, your ESP/ABS light will turn on.
Without ESP, it's easier. Remove the airbag, lower the steering wheel (it's best to mark its original position beforehand), remove the cover on the steering column, and then unscrew the unit and carefully disconnect the connectors.
Matte.
Translated on 16-09-2026, 12:03.
miguelito
31-10-2005, 8:56 Subject: Airbag Error: Causes and Solutions |
Hi Mattes,
Thanks for the instructions. I don't have ESP (Electronic Stability Program) in my car, so I just need to remove the steering wheel. I actually thought the coil spring unit could be removed from the inside (meaning the steering wheel stays in place, and only the airbag unit is removed).
By the way, how does it work when reconnecting the battery? I heard that when installing a new airbag unit, the ignition needs to be turned on before reconnecting the battery (i.e., the ignition switch must be in position I). Does that also apply when reconnecting the same unit?
Thank you.
Best regards.
Michael.
Translated on 16-09-2026, 12:05.
brezelmann01 Profi-Schrauber
Joined: 09/14/2002 Posts: 714 Karma: +75 / -0 Location: Niedersachsen
31-10-2005, 10:57 Subject: Airbag Error: Causes and Solutions |
This has nothing to do with a new car; it's purely a safety feature to prevent you from being stuck behind the wheel if the car suddenly breaks down. Audi A3 Sportback [8PA], 2.0 TDI CR [CFGB], STH mit FB
Translated on 16-09-2026, 12:07.
miguelito
03-11-2005, 10:45 Subject: Airbag Error: Causes and Solutions |
Hi Bezelmann,
mmm, that makes sense! You could even come up with it yourself with a little common sense...
Michael.
Translated on 16-09-2026, 12:08.
bafische Profi-Schrauber
03-11-2005, 13:55 Subject: Airbag Error: Causes and Solutions |
Hi Miguelito,
Sure, here's the translation:
"Just one more note:"
Extremely, extremely important! Before removing or installing, make sure not only that the steering wheel is straight, but also that the wheels are pointing straight ahead. If the steering wheel is turned a full rotation to one side, it is still straight. If you now install the steering column spring in the center position and then start driving and steering, you'll hear a "crack" and 180 Euros will be wasted.
I think I screamed in the car for about 5 minutes back then.
Best regards, "Luft und Menge müssen stimmen - der Rest ist Physik."
unumstössliches Gesetz in der Dieselmotorenentwicklung
Translated on 16-09-2026, 12:09.
