Daytime Running Lights with Dynamo
chli1976
Post10-11-2005, 7:59    Subject: Daytime Running Lights with Dynamo Quote
Here's a guide for the basic equipment needed to install daytime running lights on a Volkswagen Golf IV, specifically for users in Austria.
Okay, so this circuit works in a way that the low beam headlights only turn on when the engine is running (as long as the alternator is functioning correctly).
You will need a standard normally closed relay, which should be connected as follows:
First, remove the light switch. Then, plug a cable with a connector into the socket at TFL (17/3), and connect this cable to relay number 30.
A cable from relay number 87 is connected to terminal 56* (17/7) of the light switch.
Relay number 85 to ground.
Connect a cable from relay No. 86 to the D+ line (located in the wiring harness from the engine compartment, blue cable, 0.5 mm²), connecting it behind the relay carrier.
PS: I'll be installing it soon in a Golf IV with better equipment (and therefore more wiring), and I'll post the pictures here. However, the D+ cable should be in the same bundle.
 File size:  144.35 KB
 Viewed:  5336 times
 File size:  150.27 KB
 Viewed:  4463 times
 File size:  143.79 KB
 Viewed:  4438 times
 File size:  146.63 KB
 Viewed:  4417 times
Translated on 01-10-2026, 11:33.
Post10-11-2005, 11:34    Subject: Daytime Running Lights with Dynamo Quote
Good idea.
Do you also have the basic electrical diagrams for your images, ideally with the circuit diagrams? Have you marked your modifications on the diagrams with a red pen?
That would be great.
Translated on 01-10-2026, 11:35.
chli1976
Post10-11-2005, 13:12    Subject: Daytime Running Lights with Dynamo Quote
I have circuit diagrams.
I don't have a scanner, so I need to try and see if it works with a digital camera instead.
Translated on 01-10-2026, 11:36.
Post10-11-2005, 14:00    Subject: Daytime Running Lights with Dynamo Quote
Digicam does it too - I always do it that way icon_smile.gif.
chli1976
Post11-11-2005, 7:36    Subject: Daytime Running Lights with Dynamo Quote
Here is the circuit diagram.
I created it using CorelDraw.
 File name:  Tfl.jpg
 File size:  812.69 KB
 Downloaded:  5060 times
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts Glow Plug Information: Types, Function & More Technical Articles
No new posts Daytime Running Lights VAG-COM Installation On-Board Diagnostics (OBD)
No new posts Dim Daytime Running Lights: How & Why Transmission, Chassis, Body & Interior
No new posts LED control unit for daytime running lights On-Board Diagnostics (OBD)
No new posts Daytime running lights - 3BG, year 2004 On-Board Diagnostics (OBD)
