A4 1.9 TDI: Engine Jerks Like Clutch Slipping (Solution)
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
vagtuning
Post24-11-2005, 20:29    Subject: A4 1.9 TDI: Engine Jerks Like Clutch Slipping Quote
Problem:
The vehicle jerks when starting and engaging the clutch, similar to a slipping clutch, or the transmission makes clunking noises during sudden load changes. This is more pronounced when the vehicle is cold and disappears as the temperature increases.
Cause: Excessive flexibility of the rear gearbox mount.
Solution: For vehicles up to 8E-4-150,000 km, use transmission mount 8E0 399 105 DK (for C90 transmissions).
Alternatively, install part number 8E0 399 105 DL (for ML310 transmissions from model year 2004 onwards).
In addition to the above chassis number, the corresponding tunnel support must also be replaced due to a changed contact surface.
Translated on 10-10-2026, 16:06.
Ratings - A4 1.9 TDI: Engine Jerks Like Clutch Slipping
No new posts Causes of the shaking, Engine is shaking Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts DPF removal for Passat 3C with BMP engine Troubleshooting & Guides
No new posts DSG Jerk: 2.0 TDI Starting Issues & VCDS Data Upload
No new posts Clutch jerks when starting, especially in warm weather (A... Transmission, Chassis, Body & Interior
No new posts 1.9 TDI ATD: Engine Noise When Starting Diesel Engine Technology
No new posts Starting Problems: Lack of Power On-Board Diagnostics (OBD)
