A6 Coding Error: Dashboard Malfunction (2005)
m3nx
Post30-11-2005, 20:50    Subject: A6 Coding Error: Dashboard Malfunction (2005) Quote
Hi!
I have an Audi A6 (4F from 2005) and I want to code the instrument cluster control unit, including the seat belt warning and the Avant display in the FIS. However, the control unit seems to 'refuse' to accept any changes to the coding. Currently, the coding is 0015891. To disable the seat belt warning, for example, the correct value would be 0015801. After entering this value into my VAG-COM (which is registered and has a HEX-USB interface) and clicking 'Save,' no error message appears, but the original coding reappears in the overview. Therefore, nothing changes without any notification.
'Even trying a sequence like 0000000 or similar failed. A login version with the number 13861, which I was given as a suggestion, also didn't work.'
Has anyone ever experienced something like this before and have any ideas?
Thank you.
Translated on 24-08-2026, 20:35.
m3nx
Post07-12-2005, 11:13    Subject: A6 Coding Error: Dashboard Malfunction (2005) Quote
Since apparently no one knew about this:
The instrument cluster was incorrectly coded from the factory, so it wouldn't accept any changes to the original coding. After I 'calculated' the new code based on the list from de.openbsd.org and entered it completely, it worked.
Translated on 24-08-2026, 20:36.
This topic is locked, you cannot edit or reply. Passat 3BG 2005 Door Opening Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 05.99 to 09.2000 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Adjustment Fails: What Went Wrong? On-Board Diagnostics (OBD)
No new posts Service reset failed on Golf Sportsvan 2016 On-Board Diagnostics (OBD)
No new posts Steering Wheel Problems: Wobbles & Pulls Transmission, Chassis, Body & Interior
No new posts Car Suspension Noises on Bumps Transmission, Chassis, Body & Interior
