awissus001
Joined: 11/28/2005 Posts: 27 Karma: +0 / -1 Location: Gifhorn
28-11-2005, 8:27 Subject: Longlife Oil Change: Benefits & How-To |
Hello, I am Uwe and new to you all.
"Can anyone explain to me in a clear and understandable way how I can change the service interval on my Bora TDI 110 HP from the standard interval to the 'Longlife' interval? I've already tried searching for information, but unfortunately, I haven't found what I was looking for."
Translated on 14-08-2026, 2:41.
28-11-2005, 9:01 Subject: Longlife Oil Change: Benefits & How-To |
What is the production/model year?
What are the values in adaptation channels 40-44 of the instrument cluster, and what is the current coding of the instrument cluster? The part number might also be relevant.
Translated on 14-08-2026, 2:42.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
28-11-2005, 12:25 Subject: Longlife Oil Change: Benefits & How-To |
Of course, the engine should also support long-life oil; this is not just a software change in the instrument cluster in conjunction with a different type of oil.
Profile PM WWW Garage |
28-11-2005, 12:38 Subject: Longlife Oil Change: Benefits & How-To |
Rainer K. wrote: | | /viewtopic.php?t=3139 |
I'm not aware of an adaptation channel 45 existing for the Volkswagen Golf 4.
Possibly, you should change this point sometime.
Translated on 14-08-2026, 2:43.
Bertil Profi-Schrauber
28-11-2005, 21:01 Subject: Longlife Oil Change: Benefits & How-To |
Besswerwisser wrote: | I'm not aware of an adaptation channel 45 existing for the Golf 4.
You not, but I:
| Description: |
| File size: |
48.64 KB |
| Viewed: |
4518 times |
Translated on 14-08-2026, 2:44.
28-11-2005, 21:49 Subject: Longlife Oil Change: Benefits & How-To |
Translating... |
[Translating...]
29-11-2005, 16:20 Subject: Longlife Oil Change: Benefits & How-To |
Bertil wrote: | | You don't, but I do : |
As they say, one never stops learning...
What is the current coding of your AI?
29-11-2005, 17:09 Subject: Longlife Oil Change: Benefits & How-To |
Unlike your korrekt! (01112).
Your car is programmed for the US market. There is no "Longlife" oil change interval available there, regardless of what features are retrofitted.
There are actually some combination receivers that no longer have channel 45 (which was eventually changed to MJ04).
No idea why.
The G5 has reconnected with him (1 = fixed interest / 2 = light interest). Don't ask about the meaning.
Translated on 14-08-2026, 2:45.
29-11-2005, 17:24 Subject: Longlife Oil Change: Benefits & How-To |
Bertil wrote: | Unlike your korrekt! (01112),...
Your car is coded for the US market. There is no "LongLife" oil specification there, regardless of what features are retrofitted. |
See above, I've updated the Screenshot again; the country code has no influence on the WIV adaptation channels, neither for this AI/vehicle nor for others.
Bertil wrote: | | The G5 has him again (1 = fixed interest / 2 = low-level interest). Don't ask about the meaning. |
Because there are no more coding options available, and the WIV guidelines have finally been implemented correctly.
P.S.: But ultimately, none of this solves the original poster's problems... he really needs to post the relevant data so that people can help him.
*edit*
Problem found.
Bertil wrote: | There are actually some combinations that no longer have channel 45 (eventually MJ04).
No idea why. |
VDO combination instruments do not have channel 45, while Bosch/Motometer combination instruments do.
Therefore, we are both right.
Translated on 14-08-2026, 2:48.
awissus001
29-11-2005, 20:31 Subject: Longlife Oil Change: Benefits & How-To |
You're very welcome.
I have read your posts and will adjust the data of the instrument cluster in the next few days.
Translated on 14-08-2026, 2:50.
29-11-2005, 22:18 Subject: Longlife Oil Change: Benefits & How-To |
Besswerwisser wrote: | ...
Therefore, we are both right. |
I know that. I didn't claim that there isn't a channel 45 in general...
@ awissus001
Instead of searching, check the service booklet for the code "QG1". If it's not listed there, you don't need to look any further because your car doesn't have long-life oil specifications.
Translated on 14-08-2026, 2:51.
awissus001
10-12-2005, 15:56 Subject: Longlife Oil Change: Benefits & How-To |
Okay, thank you again for your contributions. It helped. I was able to access the service menu and enter all the settings from channel 40 to 45, but I had some problems with the oil quality setting, although it eventually worked.
Translated on 14-08-2026, 2:52.
