DIY Chip Tuning Removal: How To Undo It
ddrler
Post30-12-2005, 18:51    Subject: DIY Chip Tuning Removal: How To Undo It Quote
hello.
I haven't found anything relevant on that topic in my search.
I have a 3.0-liter car, any model, from 1999, and it was chipped (re-tuned) about a year ago.
Now I'm having the problem that the chip apparently isn't very beneficial for the engine, and I want to get rid of it. The tuner offers me the option of reversing the modification. The catch is that he's 500 km away...
Okay, so my thinking is, since the chip was replaced in my device (or at least, I believe it was), I would just need a chip with the old data and have it re-soldered in, right?
and I'm now wondering how I can get the data onto the chip (using an EPROM burner?), and could it be that the data has been encrypted or encoded? Or does everything work completely differently?
Translated on 17-10-2026, 22:15.
mullemaus
Post30-12-2005, 19:38    Subject: DIY Chip Tuning Removal: How To Undo It Quote
If the EEPROM chips have been replaced, the originals should still be present. icon_wink.gif Simply replace them with the tuning parts. Check whether they are socketed or possibly flashed. If they are socketed, just swap them out. If they are soldered, then desolder them and re-solder the 'old' ones (or have them re-soldered). icon_wink.gif If they were flashed, that would be a job for the tuner, and possibly require sending the control unit in.
Translated on 17-10-2026, 22:17.
ddrler
Post30-12-2005, 19:51    Subject: DIY Chip Tuning Removal: How To Undo It Quote
Okay, here's the translation:
"Now I have to ask a silly question: what does 'flashing' mean? Does it involve replacing the software on the original chip with a modified version? It seems like the tuner only has the software in an 'encoded' form..."
I actually thought that "flashing" (assuming that's what you mean) only works with newer engine control units (ECUs), specifically the EDC 16 series, because those can be programmed via OBD.
Translated on 17-10-2026, 22:18.
mullemaus
Post30-12-2005, 19:56    Subject: DIY Chip Tuning Removal: How To Undo It Quote
Flashing via OBD is indeed a way to do it. icon_wink.gif However, this also works with EDC15 already. icon_wink.gif Not for all, but for some. }
ddrler
Post30-12-2005, 20:01    Subject: DIY Chip Tuning Removal: How To Undo It Quote
and could you also tell me which models it already works on (EDC15) or whether and how it can be detected?
Translated on 17-10-2026, 22:19.
Rudi
Post30-12-2005, 20:05    Subject: DIY Chip Tuning Removal: How To Undo It Quote
Please provide the part number of your engine control unit (ECU).
Rudi
ddrler
Post31-12-2005, 20:17    Subject: DIY Chip Tuning Removal: How To Undo It Quote
0281010258 or is it 28SA4228? or 045906019 Q?
Ross-Tech-Support
Post02-01-2006, 0:59    Subject: DIY Chip Tuning Removal: How To Undo It Quote
ddrler wrote:
045906019 Q
That's it...
Translated on 17-10-2026, 22:20.
Rudi
Post02-01-2006, 14:25    Subject: DIY Chip Tuning Removal: How To Undo It Quote
@ddrler
It looks like there are issues with the OBD programming. This is still one of the earliest stages of PD hardware development.
(actually more like an MSA15 with flash - AFAIK without a loader).
There might be something useful in the ByteShooter (formerly FlashBooster) toolbox.
Rudi
ddrler
Post02-01-2006, 17:15    Subject: DIY Chip Tuning Removal: How To Undo It Quote
Where do you get it if you don't have it?
Translated on 17-10-2026, 22:21.
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J: Auto Volume Changes Automatically Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine temporarily maintains RPM, automatically increases... General Tips
No new posts DIY Car Tuning: Chip Tuning Guide Diesel Engine Technology
No new posts Chip Tuning: Can You Get It Done? Diesel Engine Technology
No new posts Read TDI error codes yourself... On-Board Diagnostics (OBD)
No new posts DIY VAG Connector: Build Your Own! Diesel Engine Technology
