Gurgling sounds from the center console when accelerating
Crissi
Post12-11-2002, 9:20    Subject: Gurgling sounds from the center console when accelerating Quote
Recently, I've been hearing bubbling and gurgling sounds coming from the dashboard (center console) of my AJM. Specifically, it happens when starting the engine and during the initial acceleration, as well as during acceleration in general.
I then tried to bleed the cooling system (by running the engine with the heater on and the coolant reservoir cap open).
While doing this, I noticed that every time I pressed the accelerator, bubbles would come out of the expansion tank (air bubbles).
Could this be an indication of a faulty head gasket? (Air is being forced from the combustion chamber into the cooling system), because somehow the air has to be getting into the cooling system.
Michael II
Post12-11-2002, 9:45    Subject: Gurgling sounds from the center console when accelerating Quote
This strongly suggests a faulty cylinder head gasket.
How many kilometers are on the engine?
Tschüss
Michael II
Crissi
Post12-11-2002, 11:07    Subject: Gurgling sounds from the center console when accelerating Quote
121,000 kilometers, that's a bit early, isn't it? The engine isn't tuned, and I'm more of a fuel-efficient driver who compares diesel prices. The engine doesn't really get up to full speed.
Does anyone know how much the repair will cost? Is there any possibility of getting a discount (he's 3.5 years old now)?
No new posts Vibration at Acceleration: Causes & Fixes General Tips
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts BMP ruckelt beim Beschleunigen Diesel Engine Technology
This topic is locked, you cannot edit or reply. Engine Jerk with DPF: Causes & Solutions Diesel Engine Technology
No new posts Acceleration Problem: AFN Engine Troubleshooting Diesel Engine Technology
