Fuel Injector Problem: 1Z Cylinder 4 GSK Removal?
Post07-02-2006, 11:08    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
Hi.
Do you need to disconnect the fuel line to injector 4 if you want to remove the glow plug?
Here in the forum, there's a picture that hints at this, but as far as I know, it doesn't explicitly state whether or not it *must* be done like that.
That's exactly the one I have, and I forgot to do it during the Duesen swap (where's my hammer? X).
Translated on 11-08-2026, 22:14.
cksIT
Post07-02-2006, 12:19    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
No, it's not necessary, but when screwing in the new one, you should initially start by hand to avoid tilting it. Once it's properly seated in the threads (and straight), you can easily continue with a wrench.
Translated on 11-08-2026, 22:15.
Strange
Post08-02-2006, 0:11    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
I can confirm that; I replaced my Bosch spark plugs with cheaper Beru ones after 180,000 km (3 were defective).
A long 10mm socket wrench has proven to be extremely helpful. It allows you to remove the glow plugs (spark plugs) without much hassle. (Volkswagen Golf 3)
Translated on 11-08-2026, 22:16.
kapernaum
Post08-02-2006, 6:50    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
The long-handled 10mm wrench mentioned earlier is more than worth its weight in gold for this procedure...
I've replaced the spark plugs once with the fuel injector line disconnected and once with it connected. It's a tight fit around the electrical connector, but with the long socket wrench and some careful maneuvering, you can get it done.
Translated on 11-08-2026, 22:17.
Post08-02-2006, 8:27    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
OK, thank you.
"When you take everything out, it's simple; I tested that myself. (I removed the nozzles and then, as a test, took out one spark plug to try and get things flowing because the nozzle seats were dirty)."
Once everything was put back together, I took measurements and found that the Z4 spark plug is faulty.
A 1/4" 10mm deep socket is already ready - because you can never reach the large 1/2" 10mm socket with a regular wrench icon_smile.gif.
Translated on 11-08-2026, 22:18.
Georg-TDI
Post08-02-2006, 9:06    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
OK, thank you.
A 1/4' 10mm deep socket is already ready - because you can never reach the large 1/2' 10mm socket with a regular wrench. icon_smile.gif
Then nothing can possibly go wrong!
Last winter, I also replaced all four glow plugs without disconnecting the injector lines.
Translated on 11-08-2026, 22:20.
Post09-02-2006, 9:04    Subject: Fuel Injector Problem: 1Z Cylinder 4 GSK Removal? Quote
Yep, it worked!
10-inch long nut - cross joint - extension - torque wrench.
And this morning, the test... nothing! Aaaaaaaahhhh, it's too warm!! It didn't glow!!
It started well, but he choked once or twice. It's strange that it didn't glow. My outdoor thermometer showed 4.1 degrees Celsius. But I was still on my way until 1:00 AM and then put him in the garage while he was still warm... there must have been some residual heat.
Translated on 11-08-2026, 22:21.
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts PD Injector Data: 3-Cylinder Engine Performance Technical Data
No new posts PD Injector Data: 4-Cylinder Engine Performance Technical Data
No new posts Bursting/Exploding Injector Line JR/SA Diesel Engine Technology
No new posts Audi A4 B7: Seat Occupancy Disable Coding On-Board Diagnostics (OBD)
No new posts Erwin Kicks Out Private Individuals? Dieselschrauber Bar
No new posts Water Pump Replacement VW Sharan TDI (AC Removal?) Transmission, Chassis, Body & Interior
