Vibration in the front axle during right-hand turns
BM
Avatar-BM
Post15-02-2006, 1:57    Subject: Vibration in the front axle during right-hand turns Quote
My vehicle vibrates in the front axle (without any audible noise) for example when exiting the highway in gear, as well as at a constant speed in the Lumen and when decelerating in neutral until the speed drops below 30 km/h, at which point the effect of gravity is almost negligible.
In long-radius highway curves (to the right), this is also partially noticeable.
In left-hand turns and straight-line driving, the front axle behaves normally under all load conditions.
The frequency of the vibration corresponds to the wheel's rotational speed.
Tires, wheels, wheel bearings, and all control arms are in good condition. Drive shafts are sealed.
It feels as though there is a problem with the length adjustment of the inner joint on the left drive shaft.
I hope that someone can help me and that I can avoid a swap.
3B5 AJM
pax
Avatar-pax
2000 Volkswagen Passat
Post15-02-2006, 8:41    Subject: Vibration in the front axle during right-hand turns Quote
BM wrote:
... as if the alignment of the inner joint is disrupted.
If you have already narrowed down the cause, then simply remove the gearbox-side of the driveshaft and play around with the joint a bit. Perhaps, one can already notice a certain peculiarity.
Bye
pax
BM
Avatar-BM
Post16-02-2006, 10:29    Subject: Vibration in the front axle during right-hand turns Quote
I will check this soon, as I am also planning to replace the clutch anyway.
It's not that the vibrations are very strong, but they are definitely noticeable. Interestingly, they are barely noticeable as long as I own the car (20,000 km), and only become noticeable when there are corresponding centrifugal forces acting on the front axle.
A defective inner joint should also be noticeable when driving straight ahead under load.
Maybe someone among us has already solved this specific problem, especially with the 3B5.
3B5 AJM
No new posts Document A2 8Z0044 AMF, Creaking Noise Front Axle Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Phaeton Noise: Front Axle 3D2 Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clunking Front Axle - Documentation 2D (until 03/2001) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front axle noise when turning right Transmission, Chassis, Body & Interior
No new posts Overshoot and Vibration: Causes & Solutions Diesel Engine Technology
No new posts A6 Vibration: Causes & Fixes for AEL Engine Diesel Engine Technology
No new posts Octavia 1: PD-TDI Clutch Judder/Vibration Fix Diesel Engine Technology
