wuze60 Guest
14-11-2002, 20:40 Subject: The counter nut on the VTG rod won't tighten |
Hello everyone!
I'm having the following problem: I can't seem to get the lock nut on the VTG linkage off. Is it extremely difficult to loosen from the factory, or am I just having bad luck?
Are there any tips or tricks for how to easily open a stuck jar?
I don't want to damage the  rod or the nut .
thank you in advance
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
14-11-2002, 21:03 Subject: The counter nut on the VTG rod won't tighten |
If you force the nut open, you can easily bend the rod. Therefore, you need to hold it in place with pliers or something similar.
If a standard adjustable wrench is overtightened (which hasn't happened to me so far), there are open-end wrenches available.
Profile PM WWW Garage |
wuze60 Guest
14-11-2002, 22:34 Subject: Adjustable wrench |
Greetings, Rainer
Thank you, Rainer.
So far, I've just been taking things cautiously.
I'll try holding it in place with pliers and then see if I can loosen it with a wrench.
I just wasn't sure if the thread locker, the adhesive, could be removed.
Sure, here's the translation:
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which translates to 'Sincerely' or 'Best regards' in English.
zzzZZ Guest
15-11-2002, 7:52 Subject: The counter nut on the VTG rod won't tighten |
My mother's belly hasn't moved even a millimeter, and now I can't even feel her anymore. I was even thinking about heating it up to see if I could somehow loosen the adhesive. However, I don't dare to do that while it's installed.
René K.
wuze60 Guest
15-11-2002, 18:02 Subject: My mother wasn't that strict, actually |
Hey everyone!
The mother wasn't actually that heavy.
I was just afraid of damaging something, but with a short, firm pull, it came open immediately.
Thanks again for your replies.
